Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 55
  1. #41
    Super Member JustJesus's Avatar
    Oct 2014
    Orange & LA Counties
    1,294
    Re: Review: 3D Paint Coating and 3D One Cutting Compound and Finishing Polish
    Mike in the compound video there was mention that 3D One may not need a prep wipe prior to applying the 3D coating. I do agree that 3D One is oil heavy maybe the correct word would be lubricant heavy which is why I have used a panel wipe to remove it.
    Could Tunch confirm that 3D One needs or doesn't need a panel wipe prior to the 3D coating.
    He does say to use it. It's at 25:15 in the video
    [post edited to show time and confirmation]
  2. #42
    Quote Originally Posted by JustJesus View Post
    Correct. I think this is one reason he introduced his product,
    Review: 3D Wipe Panel Wipe for Ceramic Coatings - 2009 Porsche Carrera S 997.2
    3D Wipe Surface Prep
  3. #43
    Oct 2014
    1,294
    I'm buying that next
  4. #44
    This is for my friend and Captain Michell
  5. #45
    Feb 2018
    How would you rate 3D one in terms of Cut/Finish on a scale of 1 to 10?
  6. Thanks Dan K thanked for this post
  7. #46
    SELF BANNED
    Jun 2019
    1,076
    Quote Originally Posted by miesc View Post
    3D one can remove 1500grit sanding marks is what they claim. That would make it probably a 8.5/10 on cut. But note thats with a aggressive cutting pad. To finish out you would probably have to use a less aggressive pad.
    3D one can cut that's for sure but i don't consider it a 1 step/pad product. Unless you wanted to just do a light polish of course. If you use its cutting ability be prepared to swamp out to polishing/finishing pads.
    Hopefully, Mike or someone more knowledgeable will chime in.
  8. #47
    Super Member David Fermani's Avatar
    Apr 2007
    Metro Detroit
    703
    As you can see from the date stamps, I helped Tunch/3D test their version of a ceramic coating for many years. Tunch was extremely adamant about only introducing a coating to the market if it could perform as well or better than the what was already in place. No better life experience than to work hand and hand with the owner of a chemical company who is also a chemist/inventor.
    Metro Detroit's Leader in Vehicle Preservation & Perfect Paint Finishes
  9. Thanks noorth, JustJesus, dwaleke thanked for this post
    Likes JustJesus, DetailZeus, dwaleke, SNP209 liked this post
  10. #48
    SELF BANNED
    Jun 2019
    1,076
    Quote Originally Posted by David Fermani View Post
    He's really likable. Great story.
  11. #49
    Thanks for chiming in David.
  12. #50
    Oct 2015
    411
    I always liked the approach of the 3D products, and have yet to try a coating product.
    If this is one of the easier ones to use, maybe I'll finally give a coating a try
  1. Replies: 12
    Last Post: 07-28-2021, 09:16 PM
  2. Review: 3D ONE Hybrid Cutting Compound and Finishing Polish
    Last Post: 09-03-2020, 08:27 AM
  3. Anyone like and use 3D One Cutting Compound and Finishing Polish?
    Last Post: 07-27-2020, 03:25 PM
  4. Review: 3D AAT Rubbing Compound and Finishing Polish
    By mjlinane in forum Product Reviews
    Last Post: 04-30-2016, 07:45 AM
  5. Replies: 1
    Last Post: 11-12-2015, 09:47 AM
