Results 1 to 4 of 4
    Pre-Order NOW! 40 minutes battery run time for the NEW FLEX PXE 80
    We ran a fully charged battery solid, that is we never turned her off. Re ran the tool until the battery died on it's own.
    If you fast forward to about the 40:34 time mark, that's when the tool shut down as the battery had finally died.
  2. Thanks Avgguy thanked for this post
    Likes mc2hill, Avgguy liked this post
  3. #2
    Re: Pre-Order NOW! 40 minutes battery run time for the NEW FLEX PXE 80
    In case you didn't know....
    These are now available to pre-order!
    FLEX PXE 80 12-EC KIT PRE-ORDER - $399.99
    TECHNICAL DATA:
    Max. polishing pad Ø- 3”
    Max. backing pad Ø- 3”
    Stroke- 3 & 12 mm
    No-load speed- 400-2000/-3000/-4000/-5800 rpm
    Stroke rate at no-load- 800-4000/-6000/-8000/-11600 rpm
    Battery voltage- 12V
    Battery Capacity- 2.5/4.0/6.0 Ah
    Ø battery runtime*- 2.5 Ah (up to 20 min.), 4.0 Ah (up to 35 min.), 6.0 Ah (up to 50 min.)
    Weight without battery- 1.5 lpounds
    FLEX PXE 80 12-EC KIT includes:
    • PXE 80 12-EC
    • 1 each of the adapters (1 rotary, 1 orbital 3mm and 1 orbital 12mm)
    • 1 each of the backing plates (1- 1" sticky, 1- 1" Velcro and 1- 3" Velcro)
    • Quantity of two - 2.5 Amp batteries
    • 1 charger
    • 1 Bag
    On Autogeek.com
  4. #3
    Super Member Daviddear30's Avatar
    May 2011
    1,302
    Preorded a week or two ago
    I can't wait to get itPre-Order NOW! 40 minutes battery run time for the NEW FLEX PXE 80!!
    Sent from my SM-G965U using Tapatalk
  5. #4
    Quote Originally Posted by Daviddear30 View Post
    This first shipment sold out in just a few days, fastest I've ever seen a tool sell out.
    What do you think of it so far?
  1. How long does the battery last? 40 minutes - Cordless FLEX XC 3401 aka the CBEAST
    Last Post: 11-25-2020, 10:43 AM
  2. CBEAST Battery Life aka the FLEX Cordless 3401 by Mike Phillips
    Last Post: 07-26-2019, 07:46 AM
  3. Battery Time - FLEX Cordless Polishers - Real World Detail by Mike Phillips at Autogeek
    Last Post: 03-08-2019, 12:21 PM
  4. Replies: 9
    Last Post: 04-13-2017, 12:37 PM
  5. Replies: 12
    Last Post: 02-26-2010, 02:57 AM
