Page 2 of 22 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 212
    Super Member Dan Tran's Avatar
    Sep 2015
    Portsmouth, NH
    1,055
    Re: Review: 3D ONE Hybrid Cutting Compound and Finishing Polish
    Mar 2017
    Southeastern PA
    2,480
    Man, that car looks beautiful.
    Bruno Soares
  3. #13
    Regular Member jamesalanb's Avatar
    Mar 2013
    180
    This reminds me of the Adapt review on that beautiful maroon car, almost to the T. I bought some immediately after reading that review and still use it for light to moderate swirls and defects.
    Nice review here, and kudos to 3D for continuing with excellence.
  4. #14
    Apr 2016
    Toronto, Canada
    307
    Where does HD One fit in with the existing HD Polish+ and HD Cut+? In between, like a medium polish?
  5. Likes Ronin47 liked this post
  6. #15
    From 3D
    3D ONE is a new hybrid cutting compound and finishing polish in ONE product that accelerates paint correction performance.
    3D ONE has specially engineered Nano Ceramic Alumina Abrasives that easily corrects or removes paint scratches, using a DA or high-speed rotary polisher.
    3D ONE is a unique product; apply on a cutting pad to remove heavy scratches and then apply on a finishing pad to deliver an exceptional high gloss finish.
    ONE's aggressive paint correction - cutting power will come out when used with a a stiffer cutting pad. The high performance polishing ability will be reveled with a softer polishing or finishing pad.
    It’s easy to use, and a little product goes a long way. It's easy to clean up and leaves the perfect finish every time. Works best when applied in shaded areas, but is also sun friendly.
    Directions:
    To remove scratches; shake well and apply 4 to 5 dime size drops on your choice of 3D wool or Spider-Cut foam pad and buff a 2’ X 2’ area at a time, with slow back and forth overlapping motions.
    Once the scratches are removed, apply 4 to 5 dime size drops of 3D ONE on a 3D Spider-Cut finishing pad. Polish with the same overlapping motions, keeping the pad flat to the surface.
    When the holograms and swirl marks are removed, wipe off residue with a clean microfiber towel to reveal TRUE 3D PAINT PERFECTION.
    End of 3D info
    This new compound/polish is basically a one liquid system - you adjust cut and finish by adjust pad choice.
  7. #16
    Super Member JustJesus's Avatar
    Oct 2014
    Orange & LA Counties
    1,294
    Thanks Mike!
  8. #17
    Apr 2013
    1,266
    Sounds like a nice product a newer version of adapt ?
  9. #18
    Mar 2018
    54
    That's pretty neat. I had no idea you could run polish like that over glass and chrome. Now you've really got me thinking about next steps for my Nova!
  10. #19
    SELF BANNED
    Sep 2017
    570
    Quote Originally Posted by derass View Post
    Yeah, where exactly does it fit in? Less cut than Cut +?
  11. #20
    Super Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    5,438
    As always, nice review and video.
    I'm a pretty big HD Fan and use a number of their products. As noted by others, this appears to be an updated HD Adapt of which I still have some and enjoyed using. However, in the grand scheme I continue to look for time-saving products that don't short me on results and quality. Looks like the quality of correction and finish is here with this product but my question is how much of a time saver, if any, would you say this product is?
    I continue to be a huge fan of CarPro's ClearCut on LC purple/blue wool pads for shear speed and honestly the way it finishes out, all that's left for me is a few light passes with a polishing pad and my favorite polish to complete things with a stellar finish. Where I find the big advantage to this combo is pure speed. I have cut through finishes in much worse condition than shown on this mustang in as little as 3-4 passes thus combined with polishing, I can get 95%++ correction in as little as 5-7 passes thus saving me a ton of time.
    It will be interesting to see how HD One works on wool and if it dusts. ClearCut won't dust much at all on foam but with wool it does given the nature of the fibers and how it works. I'm sure One is easier to wipe off too but ClearCut is pretty easy too.
    Thoughts?
    2023
  12. Thanks BudgetPlan1 thanked for this post
    Likes SWETM liked this post
  1. Replies: 12
    Last Post: 07-28-2021, 09:16 PM
  2. Review: 3D Paint Coating and 3D One Cutting Compound and Finishing Polish
    Last Post: 06-13-2021, 03:21 PM
  3. Anyone like and use 3D One Cutting Compound and Finishing Polish?
    Last Post: 07-27-2020, 03:25 PM
  4. Review: 3D AAT Rubbing Compound and Finishing Polish
    By mjlinane in forum Product Reviews
    Last Post: 04-30-2016, 07:45 AM
  5. Replies: 1
    Last Post: 11-12-2015, 09:47 AM
