» Detailing Classes
Page 15 of 15 FirstFirst ... 56789101112131415
Results 141 to 150 of 150
  1. #141
    Jul 2020
    Minneapolis, MN
    Re: Review: BLACKFIRE One-Step Cleaner/Wax by Mike Phillips
    I'm going to put this hear because it seems to be an appropriate spot. Please move if I am wrong. How would BF One step work with Lake Country Microfiber Polishing pads?
  2. #142
    Jun 2009
    Stuart, Florida
    49,868
    Quote Originally Posted by Skier404 View Post
    It will work great.
    BUT - if you're working on soft paint the FIBERS of the microfiber pads will scratch the paint. I call this,
    Pad Haze
    Another word if using any type of orbital polisher, (free spinning or gear-driven), would be micro-marring.
    And if using any type of fiber pad on a rotary - this scratch pattern is called holograms.
    What you're supposed to do before buffing out an entire car is called..... drum roll......
    TEST SPOT
    Do a Test Spot, this will tell show you the results from the pad, product, tool and your technique. If it looks GREAT - then repeat the Test Spot process over the rest of the car. If it looks like cr*p - then test something else.
    Great question!
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Mike Phillips Detail Training Credentials
  3. #143
    Jul 2020
    Minneapolis, MN
    It will work great.
    TEST SPOT
    Great question!
    Always have to do this!!!
    I have a FLEX CBEAST and a porter cable. Looking at LC microfiber polishing pad with BLACKFIRE One Step combination to do a 30' travel trailer in the spring. I had a typo when ordering pads a while back. Wanted 1 pad to try ended up with 10...
  4. #144
    Jun 2009
    Stuart, Florida
    49,868
    What is the surface for this travel trailer?
    Paint?
    Gelcoat?
    Something else?
    If it's gel-coat you can probably get always with microfiber pads.
    But like paint - do a Test Spot.
    That's a lot of real-estate to have to do over if you don't get it right the first time.
    Twitter
    Instagram
  5. #145
    Jul 2020
    Minneapolis, MN
    Paint?
    Gelcoat?
    Something else?
    It is painted Fiberglass. I will have to do probably 4 test spots (one for each side) to be on the safe side because the oxidation level varies.
  6. #146
    Jan 2015
    972
    If the paint is truly oxidized (chalky/powdery looking) you might consider giving it the "Comet Cleanser" treatment before attempting to polish with the AIO. That will remove most of the dead paint before you ever put your pad to the paint and will help your pad go much farther as the pad will not get so gummed/loaded up as quickly.
    As already stated... if you go this route be sure to do a test spot. One other suggestion - do the test spot in one of the worse areas. If your process works there it will work for the entire vehicle.
  7. #147
    Jun 2009
    Stuart, Florida
    49,868
    Then treat like paint. The underlying substrate has not effect on your polishing process except for heat retention and heat dissipation. Fiberglass tends to hold heat but this won't or shouldn't be a factor if using any type or brand or orbital.
    Because you say it's oxidized - this would likely mean SINGLE STAGE paint.
    Is it white? If so - white single stage paint tends to be the hardest paint there is to work on. I explain why in post #4 here,
    Barn Find - 1950 Pontiac Chieftain Deluxe Convertible - Extreme Paint Correction
    Twitter
    Instagram
  8. #148
    Jun 2009
    Stuart, Florida
    49,868
    Quote Originally Posted by 2black1s View Post
    Agree.
    Here's how to use the Comet Technique
    The COMET Technique by Mike Phillips - 1965 Cadillac - Original Single Stage Paint - Slam job by Mike Phillips
    The COMET Technique for oxidized single stage paint
    Twitter
    Instagram
  9. #149
    Jul 2020
    Minneapolis, MN
    Thanks for the Help!!! When the snow is gone here the work begins.
  10. #150
    Dec 2012
    Fl.
    239
    Hi Mike I applied BF one step one time about 2 months ago....my machine....and I am happy using....can I use it like every 2 months
  1. Review: BLACKFIRE Iron Remover by Mike Phillips
    Last Post: 04-07-2021, 09:31 AM
  2. Review: BLACKFIRE Wash and Wax by Mike Phillips
    Last Post: 08-07-2018, 05:47 AM
  3. REVIEW: BLACKFIRE Bug Remover by Mike Phillips
    Last Post: 02-20-2018, 10:11 PM
  4. Review: Blackfire Carpet and Upholstery by Mike Phillips
    Last Post: 02-20-2018, 08:28 PM
  5. How to choose and use a one-step cleaner/wax by Mike Phillips
    By Mike Phillips in forum How to articles by Mike Phillips
    Last Post: 12-30-2015, 12:29 PM
Members who have read this thread: 94
» April 2021
28293031 1 2 3
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 1
