Video: How to properly care for your tires and wheels - GYEON Wheel & Tire Care System
Jeff McEachran stopped by and together with Yancy we shot a new video showcasing the GYEON Q2 Rim.
Quartz-based protection that lasts!
GYEON Car Care offers a full range of quartz-based vehicle coatings, along with all of the tools and products needed to maintain the treated vehicle’s finish. Not only are the formulas offered the most technologically advanced, they’re also designed to be easy to use at any skill level, appealing to detailing hobbyists and professionals alike. GYEON forgoes fancy coloring and scents, providing genuine, long-lasting results that will turn heads.
GYEON is gaining a reputation worldwide as a source for the best quality car coatings. Each GYEON product is carefully crafted to provide the best results, and the best value. GYEON provides innovative solutions for high-quality surface protection that lasts longer than traditional options. That means each application yields months of protection, as opposed to mere weeks!
Blanket rims with quartz-based protection!
GYEON Q2 Rim is the only quartz-based protection product dedicated specifically for use on rims. This unique formula is extremely heat resistant, making it ideal for use on rims. Once applied, GYEON Q2 Rim protects rims from exposure to brake dust and environmental contaminants, while maintaining a like new look about the rim. And the best part is, it lasts for up to 6 months!
Your rims are exposed to more damaging contaminants than virtually any other area of your vehicle. Aside from puddles, potholes, and standard road grime, they’re also exposed to brake dust which causes irreversible damage to the finish of rims if not taken care of properly. The easiest way to maintain wheels is to seal out the contamination that causes the damage in the first place. GYEON Q2 Rim protects rims and makes it easier to keep them clean and free of brake dust.
GYEON Q2 Rim features an SiO2-based formula specifically dedicated to rims. It bonds to the surface creating a heat-resistant barrier capable of withstanding temperatures as high as 300 degrees Celsius (572 degrees Fahrenheit). The extremely hydrophobic formula produces a self-cleaning effect that makes it easier to keep wheels clean—just use a pH-neutral wheel cleaner and watch grime melt away!
Directions for Application:
Always work on a clean dry surface. Thoroughly clean the wheel to remove any iron or tar using a clay bar if necessary.
Prepare the surface for the coating using GYEON Prep to remove any residue and ensure proper bonding.
Shake GYEON Q2 Rim well.
Using the included applicator, apply a thick, even coat.
Wait 2-5 minutes for GYEON Q2 Rim to dry, then wipe off.
Allow to fully cure for 24 hours prior to driving vehicle. For faster cure time, use infrared lamps for 1 hour per rim.
On Autogeek.com
GYEON Q2 Rim - 30 ml
Last Post: 05-01-2017, 11:21 AM
By DarrylR in forum Ask your detailing questions!
Last Post: 06-15-2015, 11:05 AM
By SYMAWD in forum Product Reviews
Last Post: 06-19-2013, 10:15 PM
By icepickjazz in forum Auto Detailing 101
Last Post: 03-27-2013, 02:19 PM
Last Post: 02-17-2012, 04:37 PM
