Results 1 to 6 of 6
    Review: Wolfgang Uber Wheel Cleaner 3.0
    New updated, reformulated version 3.0 works faster while still being safe on ALL types of wheels!
    I've been using the original Wolfgang Uber Wheel Cleaner since it was introduced. It's was a great wheel cleaner because it did most of the work for you. That is, you spray it on a dirty wheel and it goes to work!
    Like the original formula, the new 3.0 updated and improved formula is non-acid and pH neutral. Plus its safe for all wheel types, chrome, aluminum, clearcoated, anodized, billet and painted wheels. You can also use it on painted and chrome wheel covers.
    Color changing performance
    The unique color-changing visual appearance shows you its working because when Wolfgang Uber Wheel Cleaner 3.0 comes into contact with iron or metallic particles created by your car's brakes it dissolves them off your wheels. The chemical reaction taking place between the wheel cleaner and the iron particles creates a red colored slurry. The more red color changing you see the worse the brake-dust contamination build-up there was on your car's wheels.
    2 in 1
    Everyone likes clean wheels but we all know that brake-dust build-up on wheels every time you drive your car. Road film is an oily residue that also builds-up on your car's wheels anytime you drive in the rain. Because road film is an oily residue it acts to lock brake dust onto your wheels and accelerates the build-up of brake dust even faster. Some wheel cleaners are really only good at removing oily road film while other wheel cleaners are really only good at removing brake dust. Wolfgang Uber Wheel Cleaner removes both the oily film and the brake dust leaving your wheels spotlessly clean.
    The initial cleaning and the maintenance cleaning
    To the casual observer these wheels don't look all that dirty.
    The thing is the mixture of oily road film and brake dust creates a corrosive film on your car's wheels that if left to the point where the wheels are turning brown chances increase that damage is taking place. That's why you need to remove brake dust and road film before it's a visual eyesore and then stay on top of it moving forward.
    The initial cleaning - The initial cleaning may require agitating the wheel cleaner to fully remove stubborn or built-up brake dust and road film. Especially in areas behind the wheels like the wheel barrels and behind the wheel spokes. For the initial cleaning I recommend having some quality specialty brushes on hand to make the job faster and easier.
    The maintenance cleaning - After you thoroughly clean your wheels moving forward the maintenance cleaning will be much easier and dramatically faster and will also require less wheel cleaner and a lot less elbow grease with the brushes.
    Brake dust and road film
    To my eyes this wheel looks fairly clean. Wolfgang Uber Wheel Cleaner is going to show you via the red bleeding effect just how much brake dust and oily road film you're eyes simply cannot see.
    Important Tip: Always work on a cool surface in the shade
    Allow plenty of time for the wheel, rotor and brakes to cool down before cleaning.
    Twice as strong with dramatically less odor
    The updated 3.0 version is now twice as strong and just as important to some of you - the chemical odor has been suppressed. This makes it much easier on the nose and a lot more pleasant to work with.
    Spray the back of the wheel barrel, then the backs of the spokes (as best as you can), and then the face of the wheel and spokes.
    Allow the wheel cleaner to dwell for about 2-3 minutes
    If there's any brake dust present you'll see the Wolfgang Uber Wheel Cleaner dissolve the brake dust and the result of the chemical reaction is called the bleeding effect as it looks like your wheels are bleeding.
    In a previous picture the wheels look fairly clean? But Uber Wheel Cleaner tells another story.
    Now here's how to get your car's wheels clean - start with the Speed Master Wheel Brush and clean the wheel barrels.
    Next, bend the flexible vinyl coated shaft to make a U-shape
    Now clean the back of the wheel spokes...
    If you like your wheels to look clean and you want to prevent a build-up of brake dust and road grime on both the barrels of the wheels and behind the spokes then you need the Speed Master Wheel Brush.
    Continued...
    The perfect wheel cleaning brush
    This is my favorite wheel cleaning brush.
    Why?
    Because the bristle are perfect for effective cleaning. They are stout enough to agitate the wheel cleaner but still flexible enough to bend and flex so the ends of the bristles can get into intricate areas. At the same time they won't scratch so they're safe for any wheel finish.
    Not only are the bristles the perfect combination of not to soft or not to stiff but the ends are flagged so they thousands of tips can agitate wheel cleaner in tight cracks, crevices and other wheel designs.
    After you use the Wheel Woolies black wheel brush one time you'll agree they are the perfect wheel cleaning brush. I use them for cosmetic engine detailing for the same reasons I like them for wheel cleaning.
    Continued...
    Big cleaning from a tiny brush
    If you consider yourself a tick on the OCD side, then you probably already own this brush. If you don't? Then get one. You'll never wash your car without one again and you'll find hundreds of other uses for this brush that will make cleaning and detailing your car faster and easier.
    The bristles are made from pig hair. and the ends are feathers or flagged which means they are split to create double and triple the number of bristles agitating the surface when you're cleaning.
    Rinse well
    After using the Speed Master Wheel Brush, the Wheel Woolies Boar's Hair Wheel Brush and the Famous Detailing Brush to agitate the Wolfgang Uber Wheel Cleaner 3.0 you're ready to blast the rim with water to flush it clean.
    Use a black wheel and tire microfiber towel to pad the wheels dry to avoid any water spotting
    Ready to hit the road!
    On Autogeek.com
    Wheel Woolies Boar’s Hair Wheel Brush
    Microfiber All Purpose & Wheel Detailing Towels - 6 Pack
    Flex Foam Tire Dressing Applicator - 3 Pack
    Re: Review: Wolfgang Uber Wheel Cleaner 3.0
    Also just to note....
    I don't always wear nitrile gloves but when I do...
    I wear Orange Heavy Duty Nitrile Gloves
    These gloves are a lot tougher than the basic black nitrile gloves and by tougher I mean they are a lot more tear-resistant. Anyone that wears these types of gloves knows the most common death of nitrile gloves is they tear.
    So if you're going to wear em... then go orange!
    Super Member Pats300zx's Avatar
    Mar 2006
    Middletown, Del
    5,297
    Great info on the new Uber wheel cleaner Mike. I loved the old version and can't think of anything that could have been improved. What has been changed in this newer version???
    Only Z Best Detailing-Automotive Concours Detailing Services
    http://ozbdetailing.com
    https://www.facebook.com/ozbautodetailing
    Super Member BudgetPlan1's Avatar
    Dec 2015
    Central OH
    2,000
    How will this get along with applied wheel coatings?
    Such as wheels coated with the Uber Ceramic? Coated with sealants such as HD Poxy?
    Is it gonna strip that stuff off?
    Dec 2015
    Central OH
    2,000
    Quote Originally Posted by BudgetPlan1 View Post
    Well, answered my own question...seems to not initially strip it. In fact, the combo of the WG Wheel Cleaner + HD Poxy + Mothers wheel brush is wonderful. Clean, shiny wheels in under 3 minutes a wheel! Used to haul out bucket, designated wheel rags, clean wheels, dry after wash, hit with QD and buff off; was the worst part of washing car...about 45min alone for wheel cleaning.
    This stuff is great! Likely have to re-apply the Poxy mid-summer as eventually it'll wear off with the cleaner but still...amazingly easy now!
    2016 Subaru dark gray painted wheels by the way. Will see how it does on chrome soon.
    Feb 2015
    Ft. Lauderdale,Fl
    615
    How does this compare to the Sonax Plus wheel cleaner?
    They both look similar in cleaning properties.
  1. Review: Wolfgang Uber Wheel Cleaner
    By AustrianOak82 in forum Product Reviews
    Last Post: 02-04-2017, 07:06 PM
  2. Review: Wolfgang Uber Wheel Cleaner/Daytona Speed Master PRO
    By Mike@DedicatedPerfection in forum Product Reviews
    Last Post: 05-31-2013, 01:02 PM
  3. Wolfgang Uber Wheel Cleaner review
    By IID in forum New Car Care Products
    Last Post: 10-31-2012, 12:53 PM
  4. Video Review: Wolfgang Uber Wheel Cleaner - Wheel Cleaning Made Simple
    Last Post: 10-19-2012, 09:02 PM
  5. The New Wolfgang Uber Wheel Cleaner
    By BorisC in forum Product Reviews
    Last Post: 10-12-2012, 10:41 AM
