» Detailing Classes
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Member
    Jul 2011
    34
    Re: Goof Off vs 3M Adhesive Remover vs Brake Cleaner for removing sticky stuff
    Guys,
    What can I use to remove the adhesive left on the trunk of my car? I bought an adhesive wheel but I don't feel comfortable using it. Can I use that Goo Gone extra strength product on the paint? Thanks
    Goof Off vs 3M Adhesive Remover vs Brake Cleaner for removing sticky stuff-trunk-emblem-jpg
    May 2017
    Beaverton, OR
    239
    Quote Originally Posted by Sixbanger View Post
    Guys,
    Goo B Gone - soak a clean cloth and press it on to the residue and let it soak/adsorb for a few moments. Try a pastic razor blade if the surrounding surface is clean. Otherwise, try using some fishing line back-n-forth and so on. I bit the bullet and rubbed at it with a MF cloth soaked in Goo B Gone and then polished out the marring I created.
  3. #13
    Senior Member Calendyr's Avatar
    Jun 2013
    Montreal, Quebec
    3,903
    I use 3M adhesive remover when I debadge vehicles. It melts the glue in seconds. Very happy with this product even if it is expensive (20$ for a can here in Canada). I have tried Goo Gone in the past and found it very ineffective. I still have a full bottle I never use. Goof off is acetone I think... might be wrong... if so, be very careful around plastic parts.
  4. Likes SWETM liked this post
  5. #14
    Senior Member Guyb's Avatar
    Dec 2014
    Kansas
    363
    I have the quart can of 3m remover and have used it to remove adhesive the goo gone and acetone would not remove. Still was a lot of work and plastic blades that day. I think I will skip the next large adhesive removal job directed my way.
  6. #15
    Senior Member sudsmobile's Avatar
    Jan 2018
    IE, SoCal
    901
    The wheel is the way to go for big jobs. It's just a big eraser. Even if you get a little marring, it's still faster to use it and then a quick polish.
  1. Adhesive Remover
    Last Post: 03-27-2018, 08:13 PM
  2. Replies: 5
    Last Post: 05-31-2016, 08:07 PM
  3. Unknown sticky stuff?
    By Purposebuilt in forum Auto Detailing 101
    Last Post: 08-14-2013, 09:45 PM
  4. Replies: 15
    Last Post: 08-05-2013, 04:53 PM
  5. Remove sticky adhesive????
    By skiptut in forum Ask Mike Phillips your detailing questions!
    Last Post: 02-26-2013, 04:30 AM
Members who have read this thread: 5
» February 2020
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
