Does anyone know how to get compound out of etched bugs???
I've been having problems with my compound filling in the etched bug marks on the hood of some of the cars, causing them to turn white and look 10x worse than they really are. And I've have very little success using mineral spirits, and goo gone to remove them. Is there a good way or technique for removing compound out of etched bug markings?
Re: Does anyone know how to get compound out of etched bugs???
One thought would be to use a APC with a soft bristle brush like one that has boars hair bristles to it, there's also peanut butter, along with claying
This must be done as you go
Once the compound is dried in the pits and etching, it is very difficult to remove without marring the paint finish
Next time you do a paint correction, the solvents in the polish will soften the compound residue that is in the defects. As soon as you finish a section, hit it with Meguiar's D114 Rinseless Wash or CarPro Eraser to make sure any residual polish is removed.
What about a toothpick? Can I just go in there and pick out the edges with a toothpick? I mean the paint is already etched anyway. A toothpick dipped in some mineral spirits should work.
Quote:
Originally Posted by
Buff-N-Glo
There's always Q-Tips dipped in isopropyl alcohol.
Bill
jamesboyy
Why on earth would you use peanut butter for this??
I'm also dubious about claying, as a pit with polish in it is effectively a sub-surface contaminant. APC with a brush sounds like the way to go.
Setec Astronomy
Because jelly is for the belly! :)
BillE
Bill
Have you tried this? This works good?
Buff-N-Glo
BillE
Buff-N-Glo
If you want to work on spots individually, knock yourself out. I would use a brush, or a MF towel, to be able to cover more surface area. Unless you are talking about 1 or 3 isolated spots. I'd skip the toothpick idea, that sounds dangerous to me.
Buff-N-Glo
use a non caustic apc,Presoaking the area then use a soft bristle toothbrush and scrub it out then rinse.
