Quick & Easy Emblem Removal
Ever since I purchased my Honda Civic Si a year and a half ago it has repeatedly been referred to as the "Honda Si" from friends, techs at the Honda dealership, and so on. Since it is currently the only model Honda makes with the "Si" designation, it makes sense. For that reason - and because I dislike taping the emblem off anyway - I decided it was time to remove the Civic emblem altogether. This makes for a much cleaner appearance.
Most emblems on vehicles manufactured in the last 25 or 30 years are attached with an adhesive backing. If you have an older car, the emblem more than likely bolts onto the panel. This guide is for removing the former.
It's real simple, so don't click away just yet. Here's a couple basic tools you will need:
http://www.autogeekonline.net/galler...php?file=95168
First you'll want to heat up the emblem using a heat gun or hair dryer. I used a hair dryer for two reasons: 1. I don't have a heat gun. 2. Less chance of damaging the panel.
You only need to heat the emblem for 15-30 seconds or so, and pay close attention to the surrounding finishes. Use the "fight or flight" method to determine if the surrounding panels are too hot. If you can't touch them without yanking your hand away in pain, then it's too hot. Take your time - better safe than sorry.
http://www.autogeekonline.net/galler...php?file=95169
Once the emblem has been heated up, take your fishing line and wrap it around your index finger on both hands. It's kind of like flossing a tooth, but much bigger. Perform a "sawing" motion as your work your way behind the emblem.
http://www.autogeekonline.net/galler...php?file=95170
http://www.autogeekonline.net/galler...php?file=95171
Normally the emblem will pop right off, but mine wasn't as easy so I simply had to pry it off with my fingers. Be careful, the emblem might still be hot from the hair dryer.
http://www.autogeekonline.net/galler...php?file=95172
http://www.autogeekonline.net/galler...php?file=95173
http://www.autogeekonline.net/galler...php?file=95174
What you see is leftover adhesive. You can remove this with a plastic razor blade, or simply use your fingernail. A plastic razor blade works much better.
http://www.autogeekonline.net/galler...php?file=95175
Once you remove the majority of the remaining adhesive, spray 3M Adhesive Remover directly onto a DAMPENED (with water) microfiber towel.
http://www.autogeekonline.net/galler...php?file=95176
GENTLY wipe the panel until all the remaining adhesive from the emblem has been removed.
http://www.autogeekonline.net/galler...php?file=95177
Tada!
http://www.autogeekonline.net/galler...php?file=95178
Just to be on the safe side, I quickly washed the panel using a rinseless wash. This is to ensure any residue from the adhesive remover is completely gone.
http://www.autogeekonline.net/galler...php?file=95179
http://www.autogeekonline.net/galler...php?file=95180
3M Adhesive Remover is pretty potent stuff, so it will remove your wax or sealant. I quickly applied a coat of Wolfgang Fuzion to protect the area.
http://www.autogeekonline.net/galler...php?file=95182
That's it!
:dblthumb2:
Re: Quick & Easy Emblem Removal
Slick!!! How did that suspension go in?!?!
nick, looks much better (and cleaner) without the badge. all the cars (including mine) in my family have all the badges taken off except for the middle logo badge (H or whatever).
Is there ever an issue of the letters shapes being left behind on cars a few (+5 years old) years older from UV fading the surrounding paint?
Quote:
Originally Posted by
Smokinss
New suspension was installed late Saturday night. So far so good. :dblthumb2:
VISITOR
It does make for a much cleaner appearance.
conman1395
It's certainly possible, but it should polish right out.
Looking good Nick!:dblthumb2:
Fishing line, Rapid Remover and polish or wax ......... golden.
Thanks for sharing your de-badging tutorial, Nick. :xyxthumbs:
Note:
Maybe it's the "old-school" that's embedded in me...
(remembering how people once desired that the vehicles
they wished to "collect" wear all that originally came with
them from the factory)...
but I like "badging".
FUNX650
Note:
Bob,
If I had a Corvette Z06 you can bet I would keep the badges on it. ;)
Bragging rights.
:dblthumb2:
If you don't have any fishing line, you can use dental floss also.
