1 Attachment(s)
Wool pad vs foam wool pad
Hi,
Should I go for Lake country's purple foamed wool pad rather than conventional wool pad? Will it cut faster and beater? Specially on hard German clear coat?
Re: Wool pad vs foam wool pad
A typical 100% Twisted wool pads will cut a little faster than a purple foamed wool, but the Purple foamed wool does have great cutting abilities and will finish with less marring than a traditional wool pad.
Not all German vehicles have hard paint, so I would always still suggest to try the least aggressive combo first. There are German Manufactures that have ceramic clear coat, which is indeed very hard. Newer Porsche vehicles are a perfect example, as you will rarely, if ever, need a compound to correct one. They are exact opposite of some other German vehicles.
Purple Foam designed to work w DA
Twisted wool is for rotary only
Quote:
Originally Posted by
David@LakeCountry
Well said Dave.
What are you trying to accomplish OP?
2 Attachment(s)
David@LakeCountry
Thanks David
Will this pad work with rotary buffer? My main concern is will it remove swirls on hard clear coats like Audi Merc. Bmw.
I have detail one Porsche Boxter I love the car & its paint. It was really soft paint came out great with polish & wax.
I just bought some of the TW pads for DA use and they seemed to work fine. Frankly, I still find it hard to use anything but foam pads, but these seem to work as well as the LC yellow CCS pads I normally use for badly marred paint.
Jim
LC is making a new Hybrid Foamed Wool Pad now too, much denser. I haven't tried it yet.
Honestly, I find the Meguiar's MF Xtra Cutting Discs to cut just as well, and they're a lot easier to maintain\clean.
surajprasade
Thanks David
Very Nice Boxter!
Yeah, the purple foamed wool pads work very well on a Rotary buffer.
I love my PFW pads on my rotary for those occasions that call for it. I haven't used a yellow LC cutting pad in lieu of the PFW in probably 3 years.
David@LakeCountry
Very Nice Boxter!
Thanks David i will definitely give it a try.
