Rupes pads...which to get
I'm about to take ownership of the Rupes 21. I also ordered the 5" Rupes backing plate. I have a question. Just a bit of history. I don't do paint correction for a living and have no desire to do so, just on my fleet of vehicles; 3-4. Two of the vehicles are only 1 years old (already corrected the paints) and my Cobra is a '95. In other words, I don't have cars with jacked up paint.
If I were to get only 2 type of Rupes pads (i.e. color), which 2 colors should I get? I want to get about 3-4 of each pad size and color.
Thanks...Al:xyxthumbs:
Re: Rupes pads...which to get
Quote:
Originally Posted by
Methodical
I would go blue cutting and yellow polishing and get the matching Rupes products.
The blue cutting pad and matching compound will tackle anything you need to correct the yellow polishing pad and matching fine cut polish will clean up anything left by the compounding process and leave the paint LSP ready.
Lots of pictures of pads and products plus the links to get them here,
The RUPES LHR21ES Random Orbit Polisher and Polishing System by Mike Phillips
Thanks. I will check them out.
Mike, what's your thoughts on the Rupes white pad?
I need a little help hear to ensure I get the proper sized Rupes pads. I have the 21 on the way, including the 5" plate. They are listed on AG as 6 and 7" pads, however, I reviewed Kevin Brown's page, which has a drawing with the dimensions of the pads. Do I go by the bottom (attaching point) or top (pad face) measurement to determine the correct sized pads?
Pad measurements:
5" pad
bottom is 130mm (5") this attaches to plate
top is 150mm (6")
AG has this pad listed as a 6" pad:
Rupes 150 mm (6 inch) Yellow Polishing Foam Pad
6" pad
bottom is 155mm (6") this attaches to plate.
top is 180mm (7")
AG has this pad listed as a 7" pad:
Rupes 180 mm (7 inch) Yellow Polishing Foam Pad
So, are these 5 and 6" inch pads or 6 and 7" pads?
Thanks
Get both of the Rupes Microfiber pads.
Methodical
It's a great finishing pad especially when paired with the Rupes Diamond Ultra Fine Cut Polish for doing your finishing work.
Works great with other fine cut and ultra fine cut polishes and also for machine applying finishing waxes and finishing sealants.
If you look at most of the projects we work on here you'll mostly see us using the 4" white Rupes pad to apply waxes. Like this,
http://www.autogeekonline.net/galler...togeek_074.jpg
http://www.autogeekonline.net/galler...togeek_075.jpg
http://www.autogeekonline.net/galler...togeek_077.jpg
I never do any paint polishing work by hand unless it's absolutely necessary.
Machine trumps Human every time.
Completely Waxed...
http://www.autogeekonline.net/galler...togeek_082.jpg
http://www.autogeekonline.net/galler...ogeek_082c.jpg
http://www.autogeekonline.net/galler...togeek_083.jpg
http://www.autogeekonline.net/galler...togeek_084.jpg
Completely unwaxed...
http://www.autogeekonline.net/galler...togeek_010.jpg
http://www.autogeekonline.net/galler...togeek_011.jpg
http://www.autogeekonline.net/galler...togeek_012.jpg
:D
HD.Detailing
The bigger is for the standard 21 BP and the smaller is for the 5" BP
Sent from my Alien Ship
Thanks that makes it really simple to remember. I figured that, but needed confirmation.
AeroCleanse
I like to foam pads. Maybe in the future I will try one of them to see how it works.
Mike.Phillips@Autogeek
Machine trumps Human every time...
:D
Thanks. So, I think I'm set. To get started with my pad collection, I will get 1-2 cutting pads (no paint correction needed on the vehicles at the moment), 3-4 polishing pads (where I spend most of my time now) and maybe a couple finishing pads (want to see if I can get that extra umph out the paint). One day I will probably go with a 4" machine, too.
I agree I only use machines to do the heavy lifting. Now, I will assume that you wipe off the wax by hand though, right.
I see how everyone stepped back and just admired the beauty of their work. It's a good feeling, especially when you finish all that hard work.
Thanks everyone...Al
