Re: New weekly wash routine?
If your only dealing with atmospheric dust then I would consider doing a rinseless or waterless wash. Both can be used on wheels as well. Coat the wheels with a sealant or coating to make cleaning easier. These should cut down on your wash time
I agree with the waterless/rinseless wash. I am in SoCal and I also just deal with atmospheric dust. I find myself doing a waterless more often on my Bee rather than a full blown wash. I'll maybe wash it once every month or two. Other than that, it is a waterless wash which takes no time at all. Just spray the product very generously and you won't have problems with scratching your paint. I was also very scared at first, not anymore.
The product I am using right now is Meguiar's D155 Last Touch Detailer straight. But I am planning on trying Pinnacle Waterless Wash w/ Carnauba.
If you keep your wheels and paint sealed with 2 coats of sealant, you should be able to just power wash it once a week and wash every 3-4 weeks.
Gary dean rinse less wash method should be all you need to do and it's fast.
I love to use the super foam from the foam gun that's why I do it every 8-10 day but don't really need to as I maintain with CG's Eco-Smart. It is quick and easy. If I am foaming and don't use the two bucket method then I will blow dry the car with a leaf blower and use a lot of QD to get any streaks left over(from Nevadas hard as cement water). Sometimes I use the rinse less method but in the end that ECO SMART is awesome. U can use any product of that sort that you like. Eco is just my GTP.
Quote:
Originally Posted by
Dombey
...is it realistic to assume that I could apply the Sonax, let it sit while I set up the pressure washer....rinse my car with the pressure washer, then coat the entire car in shaving cream thick foam...let it run off, maybe blast it again with foam...then rinse with the pressure washer...and dry with a velocity dryer?
So, said and done, no touching of the car.
Every 4-6 weeks I would do the same but use the two bucket method as well, get out the wheel woolies, etc. and then probably every 8-12 weeks I would wax (Meguiar's ultimate).
Will this routine keep my car looking nice, or am I going to need to bust out the buckets every week still?
Sent from my iPhone using Tapatalk -
now Free
:idea:
Why don't you put this plan into action, then come back and post your findings here~ should make a wonderful thread:dblthumb2:
Don't forget to mention your lsp.
