Audi S5 Extreme Makeover and opti coat @ the detailien HIVE
Always had a thing for the Audi S5.
Beautiful car... This particular Phantom Black S5 was a beautiful car with not so beautiful paint...
http://4.bp.blogspot.com/-r9v09C99Mi...0/_DSF8137.JPG
http://2.bp.blogspot.com/-Hlpe-DmqL-...0/_DSF8135.JPG
We are often asked, "How many steps paint correction do you do?", as many shops quote a 3-step, 5-step, 11-step, etc. paint correction package.
The detailien's simple answer would be, "As many as it takes...".
The art of perfecting paint is knowing not only what to do, but also what can be done and what can't.
Based on the hundreds of cars which we have done, we know what level of correction can be achieved and what tools and techniques can be used to achieve the results the owner is after.
Take this S5 for an example. The paintwork is really in quite bad shape.
Very much like a Porsche GT2 which we did some time ago...
http://2.bp.blogspot.com/-6-fqzMHfoj...0/DSCF4782.JPG
http://1.bp.blogspot.com/-GB8SNik22l...0/DSCF4784.JPG
50/50 on the Porsche.
http://2.bp.blogspot.com/-uhN6-CWmpZ...0/DSCF4796.JPG
We were able to transform the GT2 and this S5 would be no exception.
A shot of the paint before shows how bad the paint is.
http://4.bp.blogspot.com/-iFuziayt6i...0/_DSF8131.JPG
A test spot was done to see what level of correction could be achieved as this particular S5 was to be alien Coated after correction.
http://1.bp.blogspot.com/-34HDUwdUlC...0/_DSF8132.JPG
http://2.bp.blogspot.com/-GTBDXc-RJt...0/_DSF8134.JPG
The hood was taped off to carry out a 50/50 to show the owner the level of correction achieved.
Note the hazy appearance of the uncorrected hood which is what we term as holograms which was actually damage to the paint caused by previous attempts at 'detailing' this S5.
http://4.bp.blogspot.com/-MnSTj9_703...0/_DSF8138.JPG
All paint defects removed after correction.
http://2.bp.blogspot.com/-8TIPbsIjrr...0/_DSF8140.JPG
50/50.
http://2.bp.blogspot.com/-AAk_jpQ7-B...0/_DSF8150.JPG
Uncorrected...
http://4.bp.blogspot.com/-RRHbH9ZaOo...0/_DSF8145.JPG
50/50.
http://3.bp.blogspot.com/-rbgNjG9u-o...0/_DSF8146.JPG
Fully corrected.
http://4.bp.blogspot.com/-HhZOy86Ou8...0/_DSF8147.JPG
The same paint condition was found on the doors.
http://4.bp.blogspot.com/-_RgBbSkng3...0/_DSF8151.JPG
50/50.
http://1.bp.blogspot.com/-bHV1v6-1OG...0/_DSF8154.JPG
Close up of the 50/50.
http://4.bp.blogspot.com/-LUNn83S6yP...0/_DSF8153.JPG
Same on the roof. Clear damage caused by previous 'detailing' attempts.
http://1.bp.blogspot.com/-Y0EaBtCS3V...0/_DSF8155.JPG
Done.
http://2.bp.blogspot.com/-fudgQby1iU...0/_DSF8157.JPG
All ready for alien Coating.
http://1.bp.blogspot.com/-2hPRRBy048...0/_DSF8158.JPG
Do check out our page on "How to get started" for a step-by-step guide on proper car care to avoid such damage to your paint.
detailien.com- Optimum Car Care Malaysia: WHICH PRODUCTS DO I NEED?
More to come from the Hive
Audi S5 Extreme Makeover and alien Coating @ the detailien HIVE
Re: Audi S5 Extreme Makeover and opti coat @ the detailien HIVE
Great job again mate , thanx for sharing .
Black is such a rewarding colour to work on! Excellent job guys. What lsp did you use?
Nice job!!!
Are you using Optimum Products?
Great job :) I have never heard of a 11 step paint correction or as many as it takes.
Excellence as usual! :dblthumb2:
Quote:
Originally Posted by
sproketser
Thank you sprocketser for yr kind words
vdevan
Thanks vdevan
We opti coat this ride for a permemnant. Protection
mikesal57
Nice job!!!
Yes
We tries a couple opt combination
Ohp with opt cutting foam pads on flex - better
Ohc with opt cutting foam pad (green ) Makita - good for removing almost all imperfection and going twice on certain area
Finishes ohp with opt finishing pads on flex
Lastly opticoat
vet
Great job!
Thanks vet
Pureshine
Hi pure shines
Just a figure of speech, as many mass commercial car wash
Uses this phrase incorrectly
We will do as must as it requires in regardless of how many passes aka layer polish
DaGonz
Thank you sir
Amazing as usual. Keep up the great work.
Francisco
Thanks Francisco for your kind words as always
