Re: Wet sand new clear coat
Sounds like you've answered all your own questions
The only thing I would ad (which I'm sure you already know) is to be especially careful around the corners/edges
I would like to see :Picture: of your work if possible (custom bikes)
What pads or brands of pads would you recommend?
Hi Bob,
Definitely get a Griot's Garage 3" Mini Polisher and use it as a dampsander...
http://www.autogeekonline.net/galler...sanding014.jpg
Lots of pictures and links to the tool, pads, sanding discs etc that you'll want and need.
Griot's 3" Mini Polisher works great as a 3" Dampsander
Dampsanding with 3" Griot's Garage Mini Polisher
I'd also recommend getting a Flex PE14 and and an extension like you see in this pictures to make buffing out your sanding marks easy, and not a chore.
On Autogeek.net
Surgical Buffing
Working on thin panels or intricate areas is what I call surgical buffing. In order to do surgical buffing you need the right tools.
We have these new 3" pads and together with a 3" backing plate and an adapter for using double side pads but I use them as an extension.
http://www.autogeekonline.net/galler...lBuffing01.jpg
http://www.autogeekonline.net/galler...lBuffing02.jpg
http://www.autogeekonline.net/galler...nchPads011.jpg
http://www.autogeekonline.net/galler...nchPads021.jpg
http://www.autogeekonline.net/galler...nchPads031.jpg
http://www.autogeekonline.net/galler...nchPads041.jpg
On Autogeek.net
Lake Country Hydro-Tech 3 x 1.25 Inch Foam Pads, hydrotech buffing pads, polishing pads, spot buffs
Flex-Foam HD Rotary Backing Plate, 3 inches
Optimum Double-Sided Rotary Adapter
Meguiars W63 Rotary Backing Plate 3 Inches
Rotary 2 7/8 inch Flexible Backing Plate
2-3/4 inch Hook & Loop Rotary Backing Plate
Same application, just a little different design, both work great.
On Autogeek.net
Lake Country Double-Sided Pad Rotary Buffer Adapter
http://www.autogeekonline.net/galler...BExtension.jpg
Optimum Double-Sided Pad Rotary Buffer Adapter
As for compounds, Meguiar's M100 or M101 make removing sanding marks fast and easy. Get M101 if you're a foam pad guy or M101 if you're a wool pad guy.
Watch the video here for more info on these compounds...
Questions about Meguiar's M105, M101 and M100 Compounds? Watch this video!
Come to my next detailing boot camp class, I'll be covering machine sanding and compounding. I have two cars coming up and I should have one of them here for the class, either a
1969 Camaro
1971 Chevelle
Quote:
Originally Posted by
bspaint
I have some 4" wool pads from Lake Country that work really well, these were samples from Eric Dunn, (thanks Eric), but currently we don't carry them. We need too so I'll send the link to this thread to Nick and see if we can't get some onto the AG store.
We do have these brand new short pile PFW pads that just came in, hang tight and I'll take a picture for you.
:xyxthumbs:
Wow! that is an amazing amount of information so thank you. I did order the Griot's 3" orbital but I will need to wait on the Flex as this business is just starting up. Can I use the extensions, etc with the Griot's?
I will put the classes on my short list of spending my frequent flyer miles (I used to travel a lot) as I've found hands on with instructors is the best way to learn and not feel so bad about screwing up and re-fixing....
bspaint
You're welcome, we like to make this forum over the top helpful...
bspaint
Created an article to show you a few cool things and I actually answered your question about using an extension on a DA Polisher in the below article.
Click this link to see all the pictures and then look for the answer to your question...
Surgical Precision Buffing Tools
Here's a few tools for surgical precision buffing. I define surgical precision buffing as a way of using smaller pads, smaller backing plates, extensions on your rotary buffer and a lightweight, compact rotary buffer.
Using these smaller pads on a easy to hold and maneuver compact rotary buffer makes buffing out tight areas, thin panels, intricate designs, motorcycles, miscellaneous painted components like rear view mirrors, spoilers, windshield frames, a-pillars, etc. a lot easier and safer.
Going small...
http://www.autogeekonline.net/galler..._Tools_001.jpg
bspaint
You'll love the class. It's fun, educational, hands-on and I always have cool cars to work on...
