North Miami Beach Police Mobil Command Unit - Show Car Makeover
Re: North Miami Beach Police Mobil Command Unit - Show Car Makeover
Time to get BUSY!
The paint on custom trailers like these tend to be very thin, what this means is you are very limited in what you can do to actually "remove" things like swirls and especially scratches because there's just not enough film build to work with safely.
So after some testing, we chose to play it safe and machine buff the paint with the Rupes 15 and 21 Bigfoot polishers along with their white foam finishing pads and there Rupes Diamond Ultra Fine Gel Polish
What this process is going to do is remove a lot of the shallow swirls and scratches and improve, not completely remove the deeper scratches.
We all wanted to do our best and that means removing all the scratches but the paint is just too thin to do this safely.
After machine polishing the paint which will also restore a deep, dark finish, we then machine applied the Blackfire BlackICE.
Around 14 guys showed up to help out and I have to say, I was very impressed with how hard everyone worked and the teamwork taking place throughout the project.
These pictures tell the story...
Here's Paul and Robert starting out up top...
http://www.autogeekonline.net/galler...nd_Van_028.jpg
In the back is Juan, then Dan and then John...
http://www.autogeekonline.net/galler...nd_Van_029.jpg
Here's Chris aka Italian Guy...
http://www.autogeekonline.net/galler...nd_Van_030.jpg
Machine applying the new Blackfire BlackICE...
http://www.autogeekonline.net/galler...nd_Van_031.jpg
Juan machine waxing...
http://www.autogeekonline.net/galler...nd_Van_032.jpg
Robert laying down some BlackICE...
http://www.autogeekonline.net/galler...nd_Van_033.jpg
My good buddy Jeff is a machine, while most everyone else is working on the trailer he's tackling the cab...
http://www.autogeekonline.net/galler...nd_Van_034.jpg
http://www.autogeekonline.net/galler...nd_Van_035.jpg
http://www.autogeekonline.net/galler...nd_Van_036.jpg
Paul using the Rupes Bigfoot 15...
http://www.autogeekonline.net/galler...nd_Van_037.jpg
John's working the back...
http://www.autogeekonline.net/galler...nd_Van_038.jpg
Craig is using the Rupes Bigfoot 21...
http://www.autogeekonline.net/galler...nd_Van_039.jpg
Paul machine waxing...
http://www.autogeekonline.net/galler...nd_Van_040.jpg
After it cooled off a little outside we opened the garage door to let in a little more light while Craig and John worked on the back...
http://www.autogeekonline.net/galler...nd_Van_041.jpg
http://www.autogeekonline.net/galler...nd_Van_042.jpg
Here's me and Dan tackling the back upper portion...
http://www.autogeekonline.net/galler...nd_Van_043.jpg
http://www.autogeekonline.net/galler...nd_Van_044.jpg
Once down, time to turn the truck around and tackle the other side...
http://www.autogeekonline.net/galler...nd_Van_045.jpg
Here's Robert's new Porsche... nice Robert!
http://www.autogeekonline.net/galler...nd_Van_046.jpg
Fits with just inches to spare...
http://www.autogeekonline.net/galler...nd_Van_047.jpg
Continued....
Chris was so nice to tackle the greasy, grimy tires. Here he is using the Tornador Air Foam Gun with Blackfire APC...
http://www.autogeekonline.net/galler...nd_Van_063.jpg
Foam gives your product "dwell time" so the cleaners will cling to the surface where they can go to work dissolving and emulsifying dirt and in this case some type of greasy tire dressing.
http://www.autogeekonline.net/galler...nd_Van_064.jpg
Next Chris lets the Porter Cable do the scrubbing with a Cyclo Green Brush...
http://www.autogeekonline.net/galler...nd_Van_065.jpg
Later Chris put TUF Shine Tire Clear Coat on the tires...
http://www.autogeekonline.net/galler...nd_Van_066.jpg
Here's Adam aka Harleyguy taking lead on the metal polishing for the wheels... Chris and Jeff helped out too...
http://www.autogeekonline.net/galler...nd_Van_067.jpg
Here's Jeff using the Flex PE14 with some Blackfire Metal Polish on the front wheels...
http://www.autogeekonline.net/galler...nd_Van_068.jpg
http://www.autogeekonline.net/galler...nd_Van_069.jpg
Steve aka Indy, dresses all the plastic trim with Wolfgang Exterior Trim Sealant...
http://www.autogeekonline.net/galler...nd_Van_070.jpg
1000 times better... good job guys...
http://www.autogeekonline.net/galler...nd_Van_071.jpg
Craig and John tackled the diamond plate rear bumper...
http://www.autogeekonline.net/galler...nd_Van_072.jpg
http://www.autogeekonline.net/galler...nd_Van_073.jpg
http://www.autogeekonline.net/galler...nd_Van_074.jpg
http://www.autogeekonline.net/galler...nd_Van_075.jpg
Much better...
http://www.autogeekonline.net/galler...nd_Van_076.jpg
:dblthumb2:
Amazing job fellas! Well done!
Came out great Mike sorry had to leave early ran out of steam caused by a bad week at work .It's going to be hard too top that Extreme Makeover we've done some crazy cars that makeover tops the cake for sure .
Unreal, absolutely unreal! Talk about A TON of work!!!! GREAT job to everyone that was involved!! :dblthumb2:
I assume those large scratches are still there, considering only a finishing polish was used?
