Gas or electric power washer?
I've always had gas pressure washers. My last one was a HF cheapo that worked great but unfortunately sat for a couple years and didn't want to start again so I sold it at my garage sale. I more than got my money out of it. I realize electric is probably fine for washing cars, but I also like to clean my sidewalks, driveway, and wood fence with it. Will a +\- 1700 psi electric do this just as well as a 2500-3000 psi gas one?
Re: Gas or electric power washer?
Quote:
Originally Posted by
KenR
I agree. GPM is important. I bought from Pressure Washers Direct and I think they included a calculation of psi x gpm as a statistic to help with ones decision.
Sent from my Nexus 7 using AG Online
:iagree:Pressure Washers Direct - Your Online Pressure Washer Superstore - Power Washer, Power Washers, Pressure Washer for Sale, Buy Pressure Washer, Power Washer for Sale, Buy Power Washer
I say go for a nice electric one. I personally dont want to hear a gas unit running when I release the trigger. An Electric one will stop soon after you release the trigger and all is quiet.
Before buying any gas or electric pressure washer, you should see the comparisons between gas pressure washer vs electric pressure washer in link.
I decided on an electric one when I first started. Main reason was since I am mobile, it helps cut down on noise when I get an early start in close-home neighborhoods. After a lot of research, I decided on a Karcher X Series and I could not be happier. It has performed flawlessly and has stepped up to every task I have asked of it.
If considering electric, Karcher is one of the best ones out there in my opinion.
The biggest advantages of gas are using it anywhere (limited by gas available) and more pressure/power for the dollar. The electrics are usually limited to 2GPM / 1400 psi or lower gpm/slightly higher psi - limited by the 15A 120V available. They are definitely quieter, lightweight (majority are mostly plastic), and cheapest for simple models. The electrics are not usually repairable..cheaper to get a new one.
