2012 Dodge Challenger + Menzerna Color Lock Makeover
Here's the after walk-around-video...
NOTE: Internet Explorer will not display videos in the forum world so switch to a new browser.
https://www.youtube.com/watch?v=OW5gMh59nmE
Autogeek's Show Car Garage!
Tonight we're going to do an extreme makeover on a black 2012 Dodge Challenger and after we perfect the paint we're going to apply the new Menzerna Color Lock.
Here's the LSP we'll use, the brand new Menzerna Color Lock
http://www.autogeekonline.net/galler...keover_002.jpg
Menzerna in the house!
And I have a pretty good arsenal of Menzerna compounds and polishes on had and ready to go to work...
http://www.autogeekonline.net/galler...keover_001.jpg
The Challenger has arrived!
Okay Ken and his Challenger have arrived, hard to get great shots with the sun so low in the sky but here's what I took outside...
First, interesting self-portrait, now sure where I took this?
http://www.autogeekonline.net/galler...keover_003.jpg
http://www.autogeekonline.net/galler...keover_004.jpg
http://www.autogeekonline.net/galler...keover_005.jpg
http://www.autogeekonline.net/galler...keover_006.jpg
http://www.autogeekonline.net/galler...keover_007.jpg
http://www.autogeekonline.net/galler...keover_008.jpg
http://www.autogeekonline.net/galler...keover_009.jpg
Swirls and Scratches Under Florescent Lights
Here's inside, paint looks a lot worse, more scratches under the florescent lights...
http://www.autogeekonline.net/galler...keover_011.jpg
http://www.autogeekonline.net/galler...keover_012.jpg
http://www.autogeekonline.net/galler...keover_013.jpg
http://www.autogeekonline.net/galler...keover_014.jpg
The Baggie Test
And we did the Baggie Test and the paint definitely needs to be clayed...
http://www.autogeekonline.net/galler...keover_015.jpg
http://www.autogeekonline.net/galler...keover_016.jpg
Have a new car? Check out this article...
How To Detail Your Brand New Car by Mike Phillips
Re: 2012 Dodge Challenger + Menzerna Color Lock Makeover
First things first.... Ken washed his Challenger the day before but there was light dust on it so we wiped it down using Menzerna Pant Refresh...
Tim aka 57BORNTORUN misting on Menzerna Paint Refresh...
http://www.autogeekonline.net/galler...keover_017.jpg
Paul aka Sailfish wiping the paint clean...
http://www.autogeekonline.net/galler...keover_018.jpg
Claying the paint
No pictures of claying but we used Pinnacle Ultra Fine Poly Clay with Pinnacle Clay Lube.
Test Spot
Next up we did some testing and I had Robert and Paul compare the Lake Country Ultra Microfiber Pads on identical tools, the Flex 3401.
The difference was that one polisher had the THICK LC Ultra Microfiber Pad and the other polisher had the THIN Ultra Microfiber Pad.
If you want to know which one works best I'll let you post the question and I'll let Robert and Paul tell you their opinioins...
After some testing we buffed out the car using Menzerna SI 1500 with Lake Country Ultra Microfiber Pads on both the Flex 3401 and the Griot's DA Polisher and then followed that using Lake Country 5.5" white foam polishing pads with Menzerna SF 4000 and then sealed the paint using Menzerna Color Lock machine applied using Lake Country 5.5" Blue Finishing Pads on Griot's DA Polishers.
Here's Robert testing out the thick LC Ultra MF Pads and Paul testing out the thin LC Ultra MF Pads
http://www.autogeekonline.net/galler...keover_019.jpg
Robert is very good behind any polisher and always focuses on using good technique...
http://www.autogeekonline.net/galler...keover_020.jpg
Look at the THICK foam core for this MF Pad...
http://www.autogeekonline.net/galler...keover_021.jpg
Below is the thin MF pad as the foam core is much thinner than the thicker version...
NOTE: The linting is normal when breaking in a new LC Ultra Microfiber Pad
http://www.autogeekonline.net/galler...keover_022.jpg
Then I had both guys switch keeping all other variables the same except the thickness and thinness of the foam backing of the pads.
http://www.autogeekonline.net/galler...keover_023.jpg
Robert with the thin pad...
http://www.autogeekonline.net/galler...keover_024.jpg
Paul with the thick pad...
http://www.autogeekonline.net/galler...keover_025.jpg
http://www.autogeekonline.net/galler...keover_026.jpg
Hands-on Learning at Autogeek
Here's Ken working by machine for the first time. This is one of the benefits to coming to Autogeek is you get hands-on learning...
http://www.autogeekonline.net/galler...keover_027.jpg
http://www.autogeekonline.net/galler...keover_028.jpg
Here's Paul tackling the roof...
http://www.autogeekonline.net/galler...keover_029.jpg
Here's Paul using a 4 1/4" thick LC Ultra Microfiber Pad on the front lip of the car...
http://www.autogeekonline.net/galler...keover_030.jpg
The thicker foam core conforms easily to curved panesl...
http://www.autogeekonline.net/galler...keover_031.jpg
http://www.autogeekonline.net/galler...keover_032.jpg
Time to polish!
After removing the swirls, scratches and water spots using microfiber pads and Menzerna SI 1500 we switched over to foam polishing pads and Menzerna SF 4000
Hard Paint
Everyone agreed the clear coat paint on this 2012 Challenger was hard clear coat paint system...
http://www.autogeekonline.net/galler...keover_033.jpg
Here's Ken testing out the Flex 3401 with Lake Country 6.5" Foam Flat Pad...
http://www.autogeekonline.net/galler...keover_034.jpg
http://www.autogeekonline.net/galler...keover_035.jpg
Here's Robert using a Griot's DA Polisher with a Lake Country 5.5" Foam Flat pad...
http://www.autogeekonline.net/galler...keover_036.jpg
Intense focused polishing... that's the norm for Robert...
http://www.autogeekonline.net/galler...keover_037.jpg
Tim keeping all the panels wiped clean after they are machine polished...
http://www.autogeekonline.net/galler...keover_038.jpg
And here's how we knock cars out in 2-3 hours... it's called Man Power
(with machine power)
http://www.autogeekonline.net/galler...keover_039.jpg
Here's Ken machine applying the Menzerna Color Lock using a Meguiar's G110v2 DA Polisher...
http://www.autogeekonline.net/galler...keover_040.jpg
Menzerna Color Lock Carnauba Wax
http://www.autogeekonline.net/galler...keover_041.jpg
Is this going to be live broadcast?
magic mike will make it all better
the flex 3401 will take them right out mikes the man!!!!!
Quote:
Originally Posted by
Italian Guy
Not tonight, Yancy has all his equipment ready to travel or already shipped out to Lincoln, Nebraska for the wetsand, cut and buff project...
When these are live broadcasts you'll see the graphic for it included in the first post. Thanks for asking the question though as I'm sure others had the same question...
:dblthumb2:
axel06
We're going to use Flex 3401's and the new Griot's DA Polisher...
:buffing:
