As the title suggests... I'm putting on 2 coats of Klasse SG and I'm wondering how long I should wait before applying a second coat. I put one on about 3 hours ago. Can I apply another one now? In 12 hours? 24 hours?
Printable View
I think the instructions said "at least" 8-12 hours between coats. You want it to fully cure before putting on another coat. 3 hours isn't enough time. 24 hours and you are golden. I just separated the coats by daylight and come in somewhere in between 12- 24 hrs.
8-24 hours is best depending on environment.
I only have enough time to put on a coat once a week. Is it ok to wash the car, Iron X, clay and then apply the 2nd coat? In theory, I could do this weekly till I get the shine I want?
After the first coat, I would just wash it and then apply your next coat. The claying will remove some of the Klasse so that is out. And you should need to use IronX every week. I have used it after 6 months and had almost no interaction sice I keep my vehicles well maintained.
So even the fine clay will strip the Klasse Glaze? I'm afraid that since my car isn't garaged, I would get deposits in the paint between coats. So sounds like I just got wash maybe once during the week to ensure nothing embeds in the paint?
Thanks for the help
Sent from my cm_tenderloin using Tapatalk 2
