CarPro CQuartz DLux Review
CarPro CQuartz DLux
CarPro CQuartz DLux is one of their newer products designed to restore, protect all exterior plastic and rubber surfaces like trim and door moldings. If I had to categorize this product I'd say it would make a great companion to their CQuartz paint coating...
I've been using some great products lately and although they work very well I'm looking for a coating I can rely on to keep it's appearance wash after wash.....and I just may have found it!!
My truck is a 1999 Dodge Dakota SLT. While I do take very good care of it, time, weather, washing, heat and sun continues to take its toll especially on rubber and plastic.
The mirrors in particular have become dull and try as I may, all of the products I've used thus far are good for about 4 to 6 weeks. Soon after they begin to look dull again so I'm back to square 1...
The Review
CarPro CQuartz DLux
"CQuartz DLux is different from the original CQuartz formula in that DLux contains more than 50% pure silica! Silica is what makes up glass, making CQuartz DLux essentially a glass coating for your vehicle's plastic and rubber exterior surfaces. As an added benefit, the main component of CQuartz DLux is orgnosilane, a compound that repels water and dirt away from the surface it coats".
Like several CarPro products they come complete with everything you'll need in a factory sealed plastic bag..
http://www.autopiaforums.com/forums/...tz-dlux-02.jpg
Included in each kit you'll find CQuartz DLux, applicator pad, and suede cloths.
http://www.autopiaforums.com/forums/...tz-dlux-03.jpg
The bottle is shrink wrapped sealed ensuring the product remains in the bottle until it's read for use.
http://www.autopiaforums.com/forums/...tz-dlux-04.jpg
http://www.autopiaforums.com/forums/...tz-dlux-05.jpg
http://www.autopiaforums.com/forums/...tz-dlux-11.jpg
Prepping the Area
First, wash the area thoroughly then dry. Next, wipe the area with Isopropyl Alcohol to be sure it's void of oils and other contaminates.
http://www.autopiaforums.com/forums/...tz-dlux-06.jpg
http://www.autopiaforums.com/forums/...tz-dlux-07.jpg
Here's the drivers side mirror and trim. I taped off the paint not knowing whether this product could affect the paint..
http://www.autopiaforums.com/forums/...tz-dlux-08.jpg
http://www.autopiaforums.com/forums/...tz-dlux-09.jpg
Some products supplied in small bottles typically have nothing between the product and the open air once the caps removed, CQuartz DLux is not one of them. With the cap removed I was pleased to see a dispensing insert in the bottles mouth.
http://www.autopiaforums.com/forums/...tz-dlux-12.jpg
This insert makes dispensing the product on the suede cloth simple and easy.
http://www.autopiaforums.com/forums/...tz-dlux-13.jpg
Application
Now it's time to apply CQuartz DLux. I was excited to try this product because I've never been pleased with how dull some of the trim has gotten so let's see if this lives up to its claims...
I've applied it to half the mirror and as you can see the surface looks deep and rich, almost new in appearance....I am psyched!!
http://www.autopiaforums.com/forums/...tz-dlux-14.jpg
I finished the application and depending on the contour you may find your fingers are designed perfectly for those areas!
Mirror
http://www.autopiaforums.com/forums/...tz-dlux-17.jpg
This is where you drop the pad and use your fingers....with gloves of course!
http://www.autopiaforums.com/forums/...tz-dlux-15.jpg
Door Trim
http://www.autopiaforums.com/forums/...tz-dlux-16.jpg
Bug Deflector
http://www.autopiaforums.com/forums/...tz-dlux-19.jpg
http://www.autopiaforums.com/forums/...tz-dlux-21.jpg
My thoughts
CQuartz DLux is very easy to use. The product glides on effortlessly leaving a nice even coat. I applied CQuartz DLux in both directions to ensure complete and even coverage.
What surprised me was the product seemed self-leveling and absorbed into the pores of the plastic taking on a very rich appearance. CQuartz DLux dries completely with no oily feeling or residue.
At 80 degrees it cures in about 1 hour so wipe any excess with the suede cloth.
CQuartz DLux completely cures in 24 hours so don't let it come in contact with moisture during the curing time.
Believe it or not I don't think I used more than 10 drops of product to completely revive all that plastic and trim. This product is very economical to use as the product goes a very long way...:bigups
Give CarPro CQuartz DLux a try, you won't be disappointed!! :bigups
Re: CarPro CQuartz DLux Review
Bobby, thanks for the review! :props:
I bought some DLux for my father for Father's Day being that his truck needed the trim protected. I plan on using it soon and this review helped answer a couple questions. This can also be used on wheels which I plan on coating as well!
Nice review Bobby! I used this stuff recently as well. I did the bed rails, tailgate step and cowl so far. Everything looks great. I did have to use a crap load on the bed rails though, they just soaked this stuff up.
Thanks Bobby. I was looking at this stuff just last night.
Will you be updating us on its durability?
Quote:
Originally Posted by
david79z28
Yes, that's my plan! :dblthumb2:
I won't treat it any differently than I normally treat my truck. Wash once a week, dry it, and a quick look at this and another product I'm testing on the passengers mirror and trim...:props:
It's advertised to last a year but time will tell....
"It bonds strong, cleans up easily, and lasts up to one year. Now that's low-maintenance protection!"
good stuff bobby.hopefully this stuff will last.
Excellent review Bobby :props:
How long is the DLux suppose to last,approximately?
Sorry,I seen you had posted a year but with mild soap and light agitation (cleaning of bugs)maybe a bit less?
poweraid
ok I'll bite . thanks for the review Bobby . I got plenty of plastic trim on my flare side f-150 .
Be prepared to use quite a bit for the textured bed rails and tailgate step. The stuff looks great on mine but I had to really lay it on.
