1 Attachment(s)
Sticky Residue on Rear Windshield
I have a buddy that just bought a used car. On the back windshield you can see in the attached picture the sticky residue. It might look deceiving but where you see the numbers is where it is actually clean. The rest of the windshield is covered with some sticky residue that I can rub off with my finger but it would take forever. Any recommendations?
I was thinking about maybe toluene for getting something like that off glass? Would it have any adverse conditions to use toluene on glass, or does anyone have a better recommendations.
Thanks in Advance. I hope someone has seen this before.
Re: Sticky Residue on Rear Windshield
Inside or outside? I would try something a little less aggressive like isopropyl alcohol (IPA) before I went to toluene.
It's on the outside. Tried 70% IPA on a microfiber. Nothing. Open to any other suggestions. I don't think you can hurt it at this point. Maybe it isn't residue as much as just streaks in the glass. It's wierd. Glass looks distorted almost.
Quote:
Originally Posted by
RudyQ
Wash with straight APC and scrape with a "new" razorblade
Flash Gordon
Does APC=All Purpose Cleaner? Like 409?
Did you try clay bar? That usually takes most everything off the glass.
RudyQ
Uhh, well yea...
Be sure you rinse often. Don't let it (409) dry on the paint. Have someone there to help if necessary
Claybar should work too
+2 on the clay bar. Try a paint cleaner if that doesn't work.
rider9195
@rider9195: Good suggestion! :xyxthumbs:
Except for auto-glass 'crud cleaning'...I don't use this product too much any more on CC.
http://www.autogeekonline.net/galler...CutCleaner.jpg
But if you want to try a test-spot:
-M#04, on a terry cloth towel, with "some passion" (~Mike P.), on a corner-area of the rear glass.
-If you notice some improvement...
Try M#04, on a foam cutting pad, by machine---rotary's best; DA will suffice.
You're not going to be removing scratches...Just cleaning off the crud.
