Minor Correction on a Black Mercedes E-Class W212
http://i11.photobucket.com/albums/a1...k/featured.jpg
When the car arrived, I was expecting to see ton of swirls, being a black car and all. To my surprise, the owner washes it really well and there was very little car wash abrasions! Look at the photos below, granted this was before washing and there is a layer of protection on the paint that may mask those scratches, but it looks swirl free, with just the odd scratch here and there.
http://i11.photobucket.com/albums/a1...20Black/01.jpg
http://i11.photobucket.com/albums/a1...20Black/02.jpg
http://i11.photobucket.com/albums/a1...20Black/03.jpg
With the inspection done, I recommended the owner to just do some 'light' polishing to clean up the paint, and remove the holograms which I later found out was quite evident on the bonnet and boot. No heavy compounding will be necessary, so 1 day is allocated to complete the job.
I started with the wheels as usual;
Tires - Meguiar's Super Degreaser diluted 4:1
Wheel arches - Osren Degreaser FX diluted 3:1
Wheels - Bilberry Wheel Cleaner diluted 3:1
http://i11.photobucket.com/albums/a1...20Black/04.jpg
http://i11.photobucket.com/albums/a1...20Black/05.jpg
http://i11.photobucket.com/albums/a1...20Black/06.jpg
http://i11.photobucket.com/albums/a1...20Black/07.jpg
The pitted brake dust had to be removed with Osren StainX, which is a strong acid based cleaner normally used to remove watermarks from glass.
http://i11.photobucket.com/albums/a1...20Black/08.jpg
http://i11.photobucket.com/albums/a1...20Black/09.jpg
http://i11.photobucket.com/albums/a1...20Black/10.jpg
http://i11.photobucket.com/albums/a1...20Black/11.jpg
Car body is then washed with Osren Bubble and Wax shampoo with a splash of Osren Degreaser FX to help strip off the existing coat of protection. Clayed with Soft99 Clay for Black Cars with Optimum No-Rinse Wash diluted at QD (Quick Detailer) ratio.
http://i11.photobucket.com/albums/a1...20Black/12.jpg
http://i11.photobucket.com/albums/a1...20Black/13.jpg
http://i11.photobucket.com/albums/a1...20Black/14.jpg
http://i11.photobucket.com/albums/a1...20Black/15.jpg
http://i11.photobucket.com/albums/a1...20Black/16.jpg
http://i11.photobucket.com/albums/a1...20Black/17.jpg
http://i11.photobucket.com/albums/a1...20Black/18.jpg
Now let's have a better look at the clean paint.
http://i11.photobucket.com/albums/a1...20Black/19.jpg
Wow that looks pretty good, no swirls! I could escape with using an AIO and job's a good'un. But wait...
http://i11.photobucket.com/albums/a1...20Black/20.jpg
Can you see it?
http://i11.photobucket.com/albums/a1...20Black/21.jpg
Ah-hah! Holograms that were not revealed by the halogen. Halogens are good for swirl spotting and showing defects over a wider area. But when it comes to finer scratches such as holograms/buffer marks, halogen lighting does not show them very well. The light source here is from a 255 lumens LED flashlight, Eagletac T10L.
http://i11.photobucket.com/albums/a1...20Black/22.jpg
So I began by doing a test spot.
Started with Meguiar's #105 Ultra-Cut Compound with Lake Country White Polishing Pad via Dodo Juice Das6 Dual-Action Polisher. I then inspect after wiping down 3 times with Isopropyl Alcohol diluted 1:1 to remove the polishing oils that may mask the holograms.
http://i11.photobucket.com/albums/a1...20Black/23.jpg
http://i11.photobucket.com/albums/a1...20Black/24.jpg
http://i11.photobucket.com/albums/a1...20Black/25.jpg
http://i11.photobucket.com/albums/a1...20Black/26.jpg
http://i11.photobucket.com/albums/a1...20Black/27.jpg
http://i11.photobucket.com/albums/a1...20Black/28.jpg
http://i11.photobucket.com/albums/a1...20Black/30.jpg
Re: Minor Correction on a Black Mercedes E-Class W212
Success! But wait, the after shot looks a little bit 'hazy'. A 100% crop of the previous photo will reveal that DA micro-marring has been instilled to the paint.
http://i11.photobucket.com/albums/a1...20Black/29.jpg
A 2nd refining step is needed. Menzerna 106FF Finishing Polish with Lake Country White Polishing via Dodo Juice Das6 Dual Action Polisher is used to follow up. Note: this was meant to be a minor correction only, odd scratches/RIDS will not be removed.
Watch the short video for a before and after. *720P HD is available*
Hologram Removal on a Black Mercedes E Class W212 - YouTube
The rear boot however had to be compounded with a wool pad as there were deep watermark etchings.
http://i11.photobucket.com/albums/a1...20Black/31.jpg
http://i11.photobucket.com/albums/a1...20Black/32.jpg
http://i11.photobucket.com/albums/a1...20Black/33.jpg
Paint transfer removal, but couldn't save the area where the paint has been scraped off.
http://i11.photobucket.com/albums/a1...20Black/34.jpg
http://i11.photobucket.com/albums/a1...20Black/35.jpg
http://i11.photobucket.com/albums/a1...20Black/36.jpg
After about 6 hours of polishing, the car is rinsed down to remove polishing dust. Panel gaps, cracks an crevices where blown dry with my wet/dry vac.
http://i11.photobucket.com/albums/a1...20Black/37.jpg
http://i11.photobucket.com/albums/a1...20Black/38.jpg
Paint looked good without wax.
http://i11.photobucket.com/albums/a1...20Black/39.jpg
http://i11.photobucket.com/albums/a1...20Black/40.jpg
http://i11.photobucket.com/albums/a1...20Black/41.jpg
It got dark quickly and time was running up, not much photos from here on. After wiping the edges to remove polish residue, the paint is sealed with Duragloss #601 Polish Bonding Agent followed by Duragloss #105 Total Performance Polish. interior and glass were wiped down, and the front leather seats were cleaned and protected with Gtechniq L1 Leather Guard. Finally, tires dressed with ValetPro Traditional Tire Dressing.
http://i11.photobucket.com/albums/a1...20Black/42.jpg
http://i11.photobucket.com/albums/a1...20Black/43.jpg
http://i11.photobucket.com/albums/a1...20Black/44.jpg
http://i11.photobucket.com/albums/a1...20Black/45.jpg
http://i11.photobucket.com/albums/a1...0Black/45a.jpg
http://i11.photobucket.com/albums/a1...20Black/46.jpg
http://i11.photobucket.com/albums/a1...20Black/47.jpg
That's it! Thanks for looking as always, all comments are appreciated! Have a great weekend!
Wow... great job as always..
Nice work and I really enjoy your post.
