Blown 1934 Ford Pick-up - Show Car Makeover - Modeled by Kristin
As I type this it's 8:30am Saturday morning and the below street rod will be showing up any minute. I'm going to go roll out the floor mats to protect out studio tile floor while we work on this truck today and I'll try to post a couple of pictures of the truck after it arrives.
http://www.autogeekonline.net/galler...BadTruck01.jpg
Hang tight...
Re: Blown 1934 Ford Pick-up - Show Car Makeover - Modeled by Kristin
Here go...
9:00am sharp we hear a very loud rumble outside the studio, I grabbed my camera, opened the garage door and took these shots of the 34 driving toward our studio..
http://www.autogeekonline.net/galler...oject34016.jpg
http://www.autogeekonline.net/galler...oject34017.jpg
We moved the 1934 inside and then wiped the finish down using Detailer's Pro Series Waterless Auto Wash.
http://www.autogeekonline.net/galler...oject34001.jpg
http://www.autogeekonline.net/galler...ject34024a.jpg
After wiping the finish down we felt the paint using our clean hands and also using The Baggie Test.
The Baggie Test - How to inspect for above surface bonded contaminants
Both methods of inspecting the paint revealed a very clean and contaminant free finish so we skipped claying the paint.
http://www.autogeekonline.net/galler...oject34002.jpg
http://www.autogeekonline.net/galler...oject34003.jpg
Then I did my best to capture the fine or shallow swirls and scratches in the paint... hard to do with a camera but easy enough to see in person with your eyes...
http://www.autogeekonline.net/galler...oject34019.jpg
http://www.autogeekonline.net/galler...oject34020.jpg
http://www.autogeekonline.net/galler...oject34021.jpg
http://www.autogeekonline.net/galler...oject34022.jpg
http://www.autogeekonline.net/galler...oject34023.jpg
http://www.autogeekonline.net/galler...oject34024.jpg
Next we cover-up all the brightwork and there's lots of it. Take my word for it, when it comes to projects like this you don't dare get polish spatter dots on the engine or in this example the exposed running gear in the truck bed. It's not professional and besides that it would take you hours to wipe the little dots of polish splatter off.
http://www.autogeekonline.net/galler...ject34024b.jpg
http://www.autogeekonline.net/galler...ject34024c.jpg
The Autogeek Cover-up Towel is made from soft microfiber and can be washed and re-used. This come in real handy for covering up anything you don't want to get compound or polish splatter dots onto so you won't have to detail these areas with a toothbrush after the the wax has been removed.
http://www.autogeekonline.net/galler...s34pics001.jpg
The soft microfiber won't scratch paint or polished metals. Simple cover or wrap around components and then use a little painter's tape to secure them in place.
http://www.autogeekonline.net/galler...s34pics002.jpg
Here we've covered the polished aluminum gas tank and the chrome independent rear-end...
http://www.autogeekonline.net/galler...s34pics003.jpg
I got the other guys going with the Meguiar's, Porter Cable and Griot's Garage full size DA Polishers polishing all the major panels and set up the Griot's Garage 3" Mini Polishers for the smaller, tighter hard to reach areas.
Meanwhile I tackled the random, isolated deeper scratches, some by dampsanding with Meguiar's #3000 Finishing Discs and some just using the new Optimum 3" Microfiber Pads on a Flex PE 14 Rotary Buffer using Pinnacle Advanced Swirl Remover.
http://www.autogeekonline.net/galler...ng34Ford01.jpg
http://www.autogeekonline.net/galler...ng34Ford02.jpg
http://www.autogeekonline.net/galler...ng34Ford03.jpg
http://www.autogeekonline.net/galler...ng34Ford04.jpg
http://www.autogeekonline.net/galler...ng34Ford05.jpg
http://www.autogeekonline.net/galler...ng34Ford06.jpg
http://www.autogeekonline.net/galler...ng34Ford07.jpg
http://www.autogeekonline.net/galler...ng34Ford08.jpg
http://www.autogeekonline.net/galler...ng34Ford09.jpg
http://www.autogeekonline.net/galler...ng34Ford10.jpg
http://www.autogeekonline.net/galler...ng34Ford11.jpg
http://www.autogeekonline.net/galler...ng34Ford12.jpg
Continued...
After the radiator shell we moved to an area with some raised dimples on the paint, we sanded the area flat and then removed our sanding marks.
http://www.autogeekonline.net/galler...oject34025.jpg
http://www.autogeekonline.net/galler...oject34026.jpg
http://www.autogeekonline.net/galler...oject34027.jpg
http://www.autogeekonline.net/galler...oject34028.jpg
http://www.autogeekonline.net/galler...oject34029.jpg
http://www.autogeekonline.net/galler...oject34030.jpg
http://www.autogeekonline.net/galler...oject34031.jpg
http://www.autogeekonline.net/galler...oject34032.jpg
http://www.autogeekonline.net/galler...oject34033.jpg
The above is what I call Surgical Rotary Buffer work which comes in real handy for working on small or thin panels or hard to buff areas. You need an extension for your rotary buffer, small backing plates and small buffing pads.
Trend: Backing Plate Extensions for Surgical Precision Buffing
On Autogeek.net
Optimum Optimum Double-Sided Rotary Adapter
2-3/4 inch Hook & Loop Rotary Backing Plate
The Polishing or Minor Correction Step
To remove any shallow scratches, scuffs and other imperfections we used the Porter Cable 7424XP, Meguiar's G110v2 and Griot's Garage 6" and 3" DA Polishers with polishing pads and Pinnacle Advanced Finishing Polish.
Here's Brian using the Porter Cable 7424XP with a 5.5" Lake Country Black Flat Foam Polishing Pad with Pinnacle Advanced Finishing Polish on the inner portion of the driver's front fender.
http://www.autogeekonline.net/galler...oject34036.jpg
Here's Tommy using a Meguiar's G110v2 with a 5.5" Lake Country Black Flat Foam Polishing Pad with Pinnacle Advanced Finishing Polish on the driver's side roof.
http://www.autogeekonline.net/galler...oject34037.jpg
Here's Andy with PC ready to tackle the passenger's side of the roof...
http://www.autogeekonline.net/galler...oject34038.jpg
Teamwork...
http://www.autogeekonline.net/galler...oject34039.jpg
Here's Kyle using a Griot's Garage 6" DA Polisher...
http://www.autogeekonline.net/galler...oject34040.jpg
http://www.autogeekonline.net/galler...oject34041.jpg
http://www.autogeekonline.net/galler...oject34042.jpg
http://www.autogeekonline.net/galler...oject34043.jpg
http://www.autogeekonline.net/galler...oject34044.jpg
http://www.autogeekonline.net/galler...oject34045.jpg
http://www.autogeekonline.net/galler...oject34046.jpg
Using the Griot's Garage 3" Mini Polisher with a Griot's Garage 3" Foam Polishing Pad and Pinnacle Advanced Swirl Remover to remove any haze or swirls left by the rotary buffer step...
http://www.autogeekonline.net/galler...oject34047.jpg
http://www.autogeekonline.net/galler...oject34048.jpg
Andy knocking out the running boards...
http://www.autogeekonline.net/galler...oject34049.jpg
Kyle getting the inside of the pick-up bed...
http://www.autogeekonline.net/galler...oject34050.jpg
This is me working on the window frames...
http://www.autogeekonline.net/galler...oject34051.jpg
Machine polishing the visor using the Griot's Garage 3" Mini Polisher...
http://www.autogeekonline.net/galler...oject34052.jpg
Continued...
Cleaning an Optimum 3.25" Microfiber Polishing Pad using a Pad Conditioning Brush
http://www.autogeekonline.net/galler...oject34053.jpg
Start out slow on the 1 setting which is 600RPM to spread the product out after using the 10 @ 10 Technique to pick up a bead of product
http://www.autogeekonline.net/galler...oject34054.jpg
http://www.autogeekonline.net/galler...oject34055.jpg
http://www.autogeekonline.net/galler...oject34056.jpg
The 10 @ 10 technique for picking up a bead of product with a rotary buffer
Following up using a Porter Cable 7424XP to ensure any swirls are removed...
http://www.autogeekonline.net/galler...oject34057.jpg
http://www.autogeekonline.net/galler...oject34058.jpg
Machine Waxing - The Protection Step
After carefully wiping off all polishing residue we moved onto applying a coat of Wolfgang Füzion by machine. Two guys will use full size DA's and two of us will be using the 3" DA's...
http://www.autogeekonline.net/galler...oject34059.jpg
I used a hot air gun to heat the outside of the plastic jar so I could slide the wax out as a single chunk of wax and hold it in a clean Microfiber Glove...
http://www.autogeekonline.net/galler...oject34060.jpg
Then carefully swipe it across the face of a clean, foam finishing or waxing pad...
http://www.autogeekonline.net/galler...oject34061.jpg
Tommy machine waxing the rear fender...
http://www.autogeekonline.net/galler...oject34062.jpg
Getting Kyle set up to machine wax...
http://www.autogeekonline.net/galler...oject34063.jpg
Kyle machine waxing the front fender...
http://www.autogeekonline.net/galler...oject34064.jpg
The 3" Mini Polisher with a 3" Red Waxing pad works perfect on the front frame rails...
http://www.autogeekonline.net/galler...oject34065.jpg
Lance has been playing Photographer all night and as you can see by the pictures he did a great job. Here you can see him checking out the 3" Mini Polisher to machine wax...http://www.autogeekonline.net/galler...oject34066.jpg
Tommy machine waxing the inside of the bed...
http://www.autogeekonline.net/galler...oject34067.jpg
Machine waxing the paint in front of the engine...
http://www.autogeekonline.net/galler...oject34068.jpg
Machine waxing the painted steel radiator tube...
http://www.autogeekonline.net/galler...oject34069.jpg
http://www.autogeekonline.net/galler...oject34070.jpg
fhttp://www.autogeekonline.net/galler...oject34071.jpg
Where we couldn't get a machine we used soft Gold Wax Finger Pockets which worked great...
http://www.autogeekonline.net/galler...oject34073.jpg
http://www.autogeekonline.net/galler...oject34074.jpg
Time to remove the wax
Microfiber Gloves help you to grip your microfiber towels and they also prevent you from putting fingerprints on the paint...
http://www.autogeekonline.net/galler...oject34075.jpg
For the wax removal step we're using Super Soft Deluxe Green Microfiber Towels with Rolled Edges these microfiber towels are incredibly soft and gentle to highly polished paint.
http://www.autogeekonline.net/galler...oject34076.jpg
End Results...
We didn't want to get the headers hot so we pushed it out after removing the coat of Fuzion, to avoid getting finger prints on the car everyone is wearing Microfiber Gloves...
http://www.autogeekonline.net/galler...oject34005.jpg
Need to get this truck outside for a few mintutes...
http://www.autogeekonline.net/galler...oject34006.jpg
So we can roll up the protective mats...
http://www.autogeekonline.net/galler...oject34007.jpg
:hungry: Waiting to see this truck all cleaned up.
Placeholder #7
This is a placeholder for the process pictures and write-up after we've finished this project. This way the pictures and information won't be on added pages later so anyone clicking on this link will see the entire project on the first page and at the same time people can post comments and questions...
Quote:
Originally Posted by
Mike.Phillips@Autogeek
Normaly blindspots annoy me on a car, but this one I could learn to live with
What an AWESOME looking truck!!! :props:
