Anyone know if Klasse AIO and Klasse Sealant can be applied using a machine?
I have a Flex 3401.
What pad would you use? I use the Lake Country CCS pads.
Any tips or tricks?
Thanks for your advice!
Printable View
I have a Flex 3401.
Any tips or tricks?
Yes it can! Just work it into a very thin layer. I would use a blue or red CSS pad. :buffing:
I generally use a green for KAIO.
I use a blue for KHGSG. Let it cure for an hour before removing and be prepared to use a QD to get it off.
A bit of a pain but still like on light colored cars.
You can use a white pad with KAO and have the ability to do some slight correction on softer paints. Then I would go with red, blue or grey pad with the Klasse Sealant.
You can get the application instructions at this website. Go to the store, click on either the AIO or sealant, and follow the Klasse application guide. The key to both of these products, whether applied by machine or by hand is to apply it as thin as possible.
I just applied them both today. White pad with kaio on speed 5
hand applied ksg using a pinnacle foam pad. Spritzed the ksg on the pad and scrunched to prime then applied it super thin like opticoat. Had the same kind of flashing like with OC and could work down high spots just the same. I went over it with a mf after a few panels but only really needed it for places like around door handles where I couldn't really work out the high spots.
Yeah AIO with orange or white flat. And sealant with blue flat should do the trick.
