I discovered a very efficient pinstripe/decal remover.
I bought this eraser pad some time ago at a surplus store with the intention of chucking it up in a drill to do some decal removal for a customer but then he sold the truck without removing the decals so this thing sat in a box until this morning.
I was working on my friend's BMW today and knew that I was going to have to remove the pinstripes so I grabbed the eraser pad on my way out the door. When the time to remove the pinstripes came I opened up the package and noticed the 5/16" threaded arbor on this eraser pad so just for kicks I figured I would thread it into my G110V2 and see how that worked at removing the pinstripes. Man I'm gonna tell you it worked very fast and stripped the pinstripes off with no paint marring at all. It did leave a rubber like film on the paint but some light polishing by hand and the paint looked perfect.
My buddy was removing the ground effects and there was some really tough and thick double faced tape where the ground effects were so we used this eraser pad/G110V2 combo and it stripped the tape right off without a problem. Here is what it looks like and to think I was going to spend $500 for some fancy electric decal remover.
Astro Pneumatics makes the eraser pad and it sells for around $10 and screws right into a DA polisher and kicks butt at vinyl stripe removal.
http://i528.photobucket.com/albums/d...mL_AA1200_.jpg
Re: I discovered a very efficient pinstripe/decal remover.
A rotary, wool and too much pressure going after water spots will remove pinstripes handily too. Don't ask how I know this... :o
TL
Quote:
Originally Posted by
TLMitchell
TL
Yes TL, I too had learned the value of 3M blue painters tape exactly as you have outlined above.
tuscarora dave
Now that I found this $10 decal remover maybe now I can justify the $500 cost of this beautiful piece of equipment that I think I must have.
http://i528.photobucket.com/albums/d...ROS550_BBG.jpg
Yea you should be able to buy those at any body paint supply store. They will try to sell you the kit which includes the pneumatic tool but you can use it on a drill if you don't turn it up too much. Great tool for sure!!
ShineTimeDetail
Screw it into a PC and on speed 6 go to town, no marring at all and no worry about burning the paint as long as you keep it moving just like using a rotary.
Niiiiiiiice! Buying one now!
I've been using those for several years. They work great but wear out quickly. Definitely the best tool for removing decals or pinstripes.
Dave,
A simple solution is always the best way to go!!
Good Post!! :props:
