New: 1-Pad Polishing System from Lake Country
Look what came special delivery today... the new final production 1-Pad Polishing System from Lake Country.
http://www.autogeekonline.net/galler...dsystem001.jpg
Eric Dunn and Lake Country set us two sets of everything, one set to test out and one set to take to SEMA so if you're going to SEMA be sure to stop by the Autogeek Booth and check them out...
Autogeek at SEMA Information
Note: The target market for this new pad system is for high-end detailers that tend to only use new clean pads for each detailing project they tackle. There is a learning curve to this new pad/backing plate system but once you get accustomed to the thinner foam pad with the cushioned backing plate you can achieve results like a pro.
Here's the complete 1 Pad System but it's actually two lines in one... there's the 1-Pad System which includes the wool pads and the CCS Foam Pads with a *New* Hybrid Orange Cutting pad and there's the two pad, Hydro-Tech foam pad system for people that love the Hydro-Tech foam formulas.
http://www.autogeekonline.net/galler...dsystem002.jpg
1-Pad System which includes the Wool Pads and the CCS Foam Pads with a *New* Hybrid Orange Cutting pad
http://www.autogeekonline.net/galler...dsystem003.jpg
The Two Pad, Hydro-Tech foam Pad System
http://www.autogeekonline.net/galler...dsystem004.jpg
The entire system is patented and centers, (no pun intended), around the unique patented Tri-Density "Cushioned" Plate.
http://www.autogeekonline.net/galler...dsystem005.jpg
The upper yellow backing is high density foam, the black core is medium density foam and the red face is low density foam.
http://www.autogeekonline.net/galler...dsystem006.jpg
http://www.autogeekonline.net/galler...dsystem007.jpg
The backing plate is very flexible...
http://www.autogeekonline.net/galler...dsystem008.jpg
http://www.autogeekonline.net/galler...dsystem009.jpg
The red low density foam is very soft and pliable...
http://www.autogeekonline.net/galler...dsystem010.jpg
It also compresses easily under pressure...
http://www.autogeekonline.net/galler...dsystem011.jpg
http://www.autogeekonline.net/galler...dsystem012.jpg
Total width of the backing plate is approximately 1 1/4"
http://www.autogeekonline.net/galler...dsystem013.jpg
The Velcro interface measures approximately 5 3/4" in diameter and the overall width is approximately 6 1/2" in diameter.
http://www.autogeekonline.net/galler...dsystem014.jpg
http://www.autogeekonline.net/galler...dsystem015.jpg
Turning the pads over you can see the form fitting shape
http://www.autogeekonline.net/galler...dsystem016.jpg
The Velcro Interface on the back of the wool cutting pads measures approximately 4 3/4" in diameter.
http://www.autogeekonline.net/galler...dsystem017.jpg
Here again you can see the bowel shape design of the back of the pads that helps to self-center the pads onto the backing plate.
http://www.autogeekonline.net/galler...dsystem018.jpg
The hook-n-loop interface measures approximately 3 5/8" in diameter.
http://www.autogeekonline.net/galler...dsystem019.jpg
Re: New - 1 Pad Polishing System from Lake Country
Continued...
Here's some pictures of the new Hybrid Cutting Pad next to the Tangerine Hydro-Tech Polishing Pad, note the darker color. This pad with a cutting compound is said to be able to remove down to #1500 grit sanding marks and polish out LSP ready...
(Personal preference of course as to what LSP ready is)
http://www.autogeekonline.net/galler...dsystem020.jpg
http://www.autogeekonline.net/galler...dsystem021.jpg
This is a hybrid pre-polymer specially designed for Lake Country. It is more aggressive than our standard orange foam formula. Eric says this is a very unique foam pad that he thinks is really going to become popular.
http://www.autogeekonline.net/galler...dsystem022.jpg
http://www.autogeekonline.net/galler...dsystem023.jpg
Here's the backing plate mounted attached to a Flex 603 Rotary Buffer...
http://www.autogeekonline.net/galler...dsystem024.jpg
http://www.autogeekonline.net/galler...dsystem025.jpg
Here's the pad attached to the backing plate...
http://www.autogeekonline.net/galler...dsystem026.jpg
The actual diameter of the working portion of the face of the pads measures right around 6"
http://www.autogeekonline.net/galler...dsystem027.jpg
http://www.autogeekonline.net/galler...dsystem028.jpg
The high radius sides help insure that you don't run the backing plate or non-buffing portion of the buffing pad into any raised body lines or edges...
http://www.autogeekonline.net/galler...dsystem029.jpg
Continued...
Here's some screenshots from the company catalog...
http://www.autogeekonline.net/galler...ngsystem01.jpg
http://www.autogeekonline.net/galler...ngsystem02.jpg
Here's a short video we shot using pre-production, prototype pads and a pre-production, prototype backing plate.
[ame=http://www.youtube.com/watch?v=oHV-yL7htUY]YouTube - Mike Phillips Showcases Lake Country's 1-Pad Polishing System at Autogeek.net[/video]
There have been some improvements to the pads and especially the backing plate since we shot this video.
On the Autogeek.net Store
Coming soon...
Re: New: 1-Pad Polishing System from Lake Country
Nice concept and pads look promising too......great, more new thing that I must have.....it never ends...That is why I love this Business.
one time use...........that could get expensive for the detailer
What is the projected $$
Quote:
Originally Posted by
Impressions
No doubt, I hope they're cheap.
Impressions
DantheMan
I didn't get that information... I suspect a lot of people will re-use them... I just posted the information that came with the pads...
Kind of fun when you get to work in the morning and there's a mystery box on your desk...
I'll try to do some sanding and buffing test tomorrow if time allows... supposed to get some more mystery boxes in tomorrow...
:D
DantheMan
Cheap, as in 25 cents each OR LESS. By the time I throw away a regular pad I have gotten at least 100 uses out of it. Maybe even more.
oldmodman
I sent the link to this thread to Eric Dunn so I'm sure he'll value everyone's feedback.
That's something that is incredibly valuable to companies with staff wise enough to listen to end-users...
:dblthumb2:
Mike.Phillips@Autogeek
The target market for this new pad system is for high-end detailers that tend to only use new clean pads for each detailing project they tackle...
Impressions
oldmodman
Being that the 1-Pad System is marketed to those detailers that already treat normal pads as one-time-use, this will likely be a great savings at any price reduction. If you do everything you can to get the longest life from your pads, these might not be a good option. We'll see once they are released...
I like the idea of the backing plate providing consistent pressure. The thick foam of normal pads tends to "soften up" after a few passes. I could see an advantage with 1-Pad there.
