Pictures & Comments from September 19th Detailing 102 Class
Here's some pictures from our Advanced Detailing Class here at Autogeek's Show Car Garage.... This was the largest group of people I've ever had in a class like this and I would like to thank everyone for being so attentive and pro-active to really join in during the hands-on portions of the class.
I would also like to thank Don for being our class photographer and Robert from Impressions Detailing for lending a hand to make sure everyone was provided any technical help throughout the day plus helping to clean up after the class was over.
Without further ado...
http://www.autogeekonline.net/galler...DVClass002.jpg
http://www.autogeekonline.net/galler...DVClass003.jpg
http://www.autogeekonline.net/galler...DVClass004.jpg
Demonstrating correct hand-sanding techniques starting with Meguiar's Nikken #1500 Unigrit Finishing Papers
http://www.autogeekonline.net/galler...DVClass005.jpg
After sanding you can often times use a clean sanding backing pad to squeegee off the water slurry to then inspect your progress...
http://www.autogeekonline.net/galler...DVClass006.jpg
http://www.autogeekonline.net/galler...VClass006c.jpg
Refining the #1500 grit sanding marks by re-sanding using with Meguiar's Nikken #2000 Unigrit Finishing Papers
http://www.autogeekonline.net/galler...DVClass007.jpg
http://www.autogeekonline.net/galler...DVClass008.jpg
http://www.autogeekonline.net/galler...DVClass009.jpg
Before we start machine sanding we used some thin, 3M vinyl tape to cover the raised body lines on the Chevrolet Truck Hood so we'll be able to easily avoid sanding over the them. The sanding slurry created by machine tends to cover and make it hard to see raised body lines and it only takes a few seconds of sanding to burn-through high points.http://www.autogeekonline.net/galler...DVClass010.jpg
http://www.autogeekonline.net/galler...DVClass011.jpg
http://www.autogeekonline.net/galler...DVClass012.jpg
Now it time for the students to sand with both #1500 and #2000 Finishing Papers
http://www.autogeekonline.net/galler...DVClass013.jpg
http://www.autogeekonline.net/galler...DVClass014.jpg
http://www.autogeekonline.net/galler...DVClass015.jpg
Re: Pictures & Commnets from September 19th Detailing 102 Class
Great class Mike!! :buffing:
Thanks to Max for letting us have the chance to learn from the best! :dblthumb2:
There were alot more people than expected but Mike seemed all too happy to give his thoughts and expertise to all who attended.
Even if I just picked up one or two tips from the class it is still something learned and I try to learn something new every day!
Thanks again Max, Mike, Meghan and Dwayne
Thanks to all who attended for making a crowded class enjoyable :dblthumb2:
After hand sanding it was time to dampsand... first a demonstration sanding with #1500 Unigrit Foam Backed Discs first followed by #3000 Unigrit Foam Backed Discs... then everyone is encouraged to try their hand at machine dampsanding...
We used clean water, no soap or lubrication to dampen the paint and the sanding disc...
http://www.autogeekonline.net/galler...DVClass017.jpg
http://www.autogeekonline.net/galler...DVClass018.jpg
Set the DA Polisher on the 5.0 Speed Setting
http://www.autogeekonline.net/galler...DVClass019.jpg
Rapid arm speed...
http://www.autogeekonline.net/galler...DVClass020.jpg
Light pressure, just a little more than the weight of the machine...
http://www.autogeekonline.net/galler...DVClass021.jpg
http://www.autogeekonline.net/galler...DVClass022.jpg
Easy enough to control with one hand but you should use two hands...
http://www.autogeekonline.net/galler...DVClass023.jpg
Overlapping motions, criss-cross pattern...
http://www.autogeekonline.net/galler...DVClass024.jpg
The white residue you see on the panel is actually clear coat paint particles suspended in water, this is called your sanding slurry...
http://www.autogeekonline.net/galler...DVClass025.jpg
Switching over to #3000 Unigrit Foam Backed Discs...
http://www.autogeekonline.net/galler...DVClass026.jpg
Center the disc onto the backing plate...
http://www.autogeekonline.net/galler...DVClass027.jpg
http://www.autogeekonline.net/galler...DVClass029.jpg
Here's Tanya showing the guys how it's done...
http://www.autogeekonline.net/galler...DVClass046.jpg
Expert technique and profession results her first time....
http://www.autogeekonline.net/galler...DVClass045.jpg
http://www.autogeekonline.net/galler...DVClass044.jpg
:xyxthumbs:
I really enjoyed the class Mike.
Having attended the 101 class last year on a weekend where 102 was not offered, I have been eagerly awaiting a 102 class.
My intentions in attending this class were to have a try at handling rotaries since I only use a Flex at home and to see if I could pick up any wetsanding techniques that I might use for minor repairs on my personal vehicles if needed. I don't do this for a living, it is just a hobby. (obsession??)
That said, I felt that the class more then met my expectations. Although a scheduling snafu made the class larger then Mike expected, it went well with more then ample time for me to test the machines, techniques and products that I wanted to try.
So I got to try out hand sanding, sanding with a DA and most importantly tried out the rotaries with 105/205 and the optimum polish and compound. My initial impressions are that I like 105 better with a rotary then a flex and that the Makita is the class of the bunch when it comes to a rotary. I liked the optimum spray polish but not as happy with the optimum spray compound.
The new classroom is fantastic, well designed, large and most importantly air conditioned! Mike as always was a pleasure, taking time to answer individual questions while keeping the class moving along. Mike checked in constantly to ensure that everyone was getting time on the machines/techniques/products that they wanted to. He must have asked 10 times during the day to check that everyone was happy.
It was great to see Dwayne and Megan, they are always a joy. Dwayne was our helper extraordanaire during the day, helping out Mike, helping customers place orders during breaks and taking photos. Megan popped by a few times to ensure everyone was behaving!
I got to meet/interact with some forum folks as well. I've met Robert (Impressions) before and he was making sure folks were using the correct technique. Shane (Ciera SL) was there on his great adventure and was nice to talk to during class. Don was our class photographer and a great guy. Took the time during his class to take photos of everyone having fun. Jay (John Henry) is a class act and we took time to talk about detailing. He also bears a remarkable resemblance to his avatar! (just joking Jay, nice talking with you)
Andris and Tanya were also fun too.
If you haven't attended a class at AG, you are missing out on a great time with a quality staff. Plus the added bonus of being in a room with a bunch of other Auto-Geeks! Next time one is offered, don't think about it just do it.
Here's my photos from the day.
Shane trying out the DeWalt and the Menzerna
http://www.autogeekonline.net/galler...05/photo_6.JPG
Mike putting a pad on the DeWalt
http://www.autogeekonline.net/galler...5/photo_51.JPG
Look Mom! Only one hand
http://www.autogeekonline.net/galler...5/photo_42.JPG
BOLO - If you have seen this man, contact the local FBI office. Dwayne taking some photos on his really cool Samsung
http://www.autogeekonline.net/galler...5/photo_32.JPG
Look how sanded out that hood is!
http://www.autogeekonline.net/galler...5/photo_22.JPG
Mike taking the money shot
http://www.autogeekonline.net/galler...5/photo_12.JPG
Thanks for a great class!
Next up is learning to use a rotary buffer with a wool cutting pad and an aggressive compound to remove the sanding marks and restore gloss...
It's important to wear safety glasses anytime you're operating power tools...
http://www.autogeekonline.net/galler...DVClass059.jpg
Demonstrating the 10 @ 10 Technique for picking up a bead of product...
http://www.autogeekonline.net/galler...DVClass060.jpg
With this technique you run the bead of product into that pad at the 10 O'Clock position on the pad while tilting the pad approximately 10 degrees moving the buffer from right to left...
http://www.autogeekonline.net/galler...DVClass061.jpg
http://www.autogeekonline.net/galler...DVClass062.jpg
When you do this instead of splattering the product outward, the pad will pull the product into into itself and under the pad...
http://www.autogeekonline.net/galler...DVClass063.jpg
After you pick up your bead you can then lay your pad flat, spread the product out over the area you're going to work and begin making slow, overlapping passes.
http://www.autogeekonline.net/galler...DVClass064.jpg
http://www.autogeekonline.net/galler...DVClass065.jpg
http://www.autogeekonline.net/galler...DVClass066.jpg
http://www.autogeekonline.net/galler...DVClass067.jpg
http://www.autogeekonline.net/galler...DVClass068.jpg
http://www.autogeekonline.net/galler...DVClass069.jpg
http://www.autogeekonline.net/galler...DVClass070.jpg
The goal is to remove all of the sanding marks and restore gloss and clarity to the paint. It's okay if there are still swirls left behind as we'll remove those during the polishing step.
http://www.autogeekonline.net/galler...DVClass071.jpg
http://www.autogeekonline.net/galler...DVClass072.jpg
Large classes are easily manageable as long as the topic is interesting and entertaining and the people are their to learn... and this was a very focused group of people...
http://www.autogeekonline.net/galler...DVClass073.jpg
http://www.autogeekonline.net/galler...DVClass074.jpg
http://www.autogeekonline.net/galler...DVClass075.jpg
:xyxthumbs:
Autogeek Detailing 101 and 102 classes are Highly Recommended!
This question comes up periodically on the forums... "Where can I find detailing training?" Right here, folks! Autogeek provides the best quality and value in detailing training. As a bonus, you will already know almost everyone in class, your fellow forum members.
No, I am not affiliated with AG. Yes, I would return tomorrow if they provided another class. What else can I say? Thanks, Mike! Excellent presentation, as always!
It was great to see some old buds... Meghan, Jason, and Dwayne. (No , he is not a fugitive from justice. He only looks like those guys on the Post Office wall.)
And I met some cool new friends... TMark (Dude, are you a long-lost cousin? lol), Impressions (Robert, I will be down to take a graduate course in your shop soon!), McHess (John, nice ride!), CieraSL (Shane, you lucky dog!) , and the nicest couple you will ever meet, Pamper My Ride, Andris and Tanya, from Latvia, via Jacksonville.
Sorry we did not have enough time to get to know everyone. Next time, for sure!
I think its great too that we have had a lot of women attending lately, Mike has done a great job getting them to master the polishers just like the boys.
Continued...
Next up, using the rotary buffer with a foam polishing pad and a polish to remove the swirls left by the compounding process and restore a clear, high gloss finish...
Here's Jeff using the Flex Rotary Buffer with M205...
http://www.autogeekonline.net/galler...DVClass103.jpg
Here's Astrid using the DeWALT Rotary Buffer with Menzerna PO83 SIP
http://www.autogeekonline.net/galler...DVClass104.jpg
Antonio using the Makita Rotary Buffer with Optimum Hyper-Polish...
http://www.autogeekonline.net/galler...DVClass105.jpg
Julio using the DeWALT Rotary Buffer with Menzerna PO83 SIP
http://www.autogeekonline.net/galler...DVClass106.jpg
http://www.autogeekonline.net/galler...DVClass107.jpg
http://www.autogeekonline.net/galler...DVClass108.jpg
Javier checks out the results using the Brinkmann Swirl Finder Light...
http://www.autogeekonline.net/galler...DVClass109.jpg
http://www.autogeekonline.net/galler...DVClass110.jpg
I'm standing on a step stool to take some of the above photos and I see Hugo getting ready to take my picture, so I take his picture at the same time...
http://www.autogeekonline.net/galler...DVClass111.jpg
Happy people having fun at Autogeek's Show Car Garage!
http://www.autogeekonline.net/galler...DVClass112.jpg
Alfred testing out Hyper-Polish...
http://www.autogeekonline.net/galler...DVClass113.jpg
Shane testing out Menzerna PO83 SIP with a DeWALT and a 3M Convoluted Polishing Pad...
http://www.autogeekonline.net/galler...DVClass114.jpg
http://www.autogeekonline.net/galler...DVClass115.jpg
And now it's time for Tanya to show the guys how it's done...
http://www.autogeekonline.net/galler...DVClass116.jpg
Tanya sprays the Optimum Hyper-Polish onto the face of the Optimum Foam Polishing Pad...
http://www.autogeekonline.net/galler...DVClass117.jpg
When using a rotary buffer you need to focus on the task at hand... she's got that down...
http://www.autogeekonline.net/galler...DVClass118.jpg
Notice in the above and below pictures how Tanya's opted to hold the head of the polisher instead of the D-Handle? Holding the head, or in other words getting her grip closer to the transfer point of power to paint gives here more leverage over the tool and makes buffing easy... of course Hyper-Polish has an excellent buffing cycle and that makes it super easy to buff with...
Perfect technique
http://www.autogeekonline.net/galler...DVClass119.jpg
Marketing...
http://www.autogeekonline.net/galler...DVClass120.jpg
Here's Bill buffing with the Makita...
http://www.autogeekonline.net/galler...DVClass121.jpg
Here's Paul using the DeWALT...
http://www.autogeekonline.net/galler...DVClass122.jpg
Here's Robert testing out the Mother's Foam Pad Polish with the DeWALT Rotary Buffer...
http://www.autogeekonline.net/galler...DVClass123.jpg
:D
