Hi everyone. I finally got around to starting in on doing my Yukon (much more vehicle to work with than was my Civic!) and noticed something with the pads. I'm using the PC with the Wolfgang pads, and as I got more of the truck done, it seemed as though the pad wasn't doing much of anything. By doing nothing I mean that whereas when I first started, everything was fine, the polish got worked, it broke down, yada yada. But as I did more of the truck, the PC wasn't even spinning the pad at all, it was just kind of vibrating a little bit as if the pad was getting stuck and not doing much of anything else other than throwing some dried polish on my arms from the edges of the pad. The polish wasn't breaking down since it wasn't getting worked properly, and in some places I was getting buildups of polish, while in others it was kind of leaving behind the (for lack of knowing how to describe it) wetness of the polish. I didn't run into this problem with the Civic, so the questions are these: Are the pads only good for X amount of time until they get clogged with polish? Did I use too much polish? Do I just need to switch to a new pad when it starts doing this? Does any of what I am trying to explain make sense to you all?? :D
