Collinite 845 Insulator Wax Review
Let me state from the very beginning, this is NOT a new product, its been around for decades. But its one of those if-you-know-you-know products.
Wax is NOT Dead! And while Collinite 845 has been discussed in this area of the forum many times, those threads are somewhat old now, so this is a fresh take on an old product.
Backstory
Collinite 845 comes from a time when the ultimate in paint protection centered around polymer sealants and carnauba waxes. However, over the last 10 to 15 years, these products have been sidelined for modern ceramic coatings and spray sealants. When you consider a ceramic coating will outlast and outshine any wax on the market many times over, you can appreciate why these products have taken over the car care market. But……………..
I have always maintained there is still very much a place for waxes in modern car care. Why? Because for some reason, a freshly waxed car has a certain look that is hard to describe but most definitely a thing. Ceramic coatings and ceramic spray sealants are often described as stark and glassy looking, almost sterile. A wax on the other hand provides a mellow, warmer appearance, something that can help highlight non-metallic colors. I have also found that for the most part, older waxes and polymer sealants have an edge in slickness.
Gyeon Q2 Wax (ceramic wax) -
https://www.mustang6g.com/forums/att...81-jpg.815127/
https://www.mustang6g.com/forums/att...63-jpg.815128/
Wolfgang Deep Gloss Paint Sealant (polymer sealant) -
https://www.mustang6g.com/forums/att...99-jpg.815129/
https://www.mustang6g.com/forums/att...16-jpg.815130/
Of course, there are drawbacks. As mentioned earlier, a wax is never going to win awards for chemical resistance or longevity, meaning you need to apply them more often. But I can flip that negative into a positive by saying that gives the user more flexibility to try different products. You also don’t need to hammer down on the paint to remove the remains of the wax before reapplication like you would with a ceramic coating. And finally, there is something so tactile about applying a wax and then buffing off a wax.
What Is It and What Does It Do?
With American origins, Collinite are one of those sleeper brands that have been making car care products since 1912. By and large, the products Collinite sell right now are the same as they were 20 years ago. In some ways, that is a foolish game to play when countless brands have come along since and innovated themselves into contention. So, out of all the countless waxes still on the market, why is Collinite 845 Insulator Wax my ultimate choice? Because it just works!
Collinite Liquid Insulator Wax #845, liquid wax, heat-resistant wax, car wax (autogeek.net)
https://www.mustang6g.com/forums/att...44-jpg.815131/
Collinite 845 Insulator Wax was not originally intended for use on cars. As the name suggests, this product was used as an insulator for electrical components, helping to protect against high voltage power failure, electrical fires, and explosions. It somehow transitioned over to automotive use and has been protecting cars for decades now.
The first thing you notice with 845 is the lack of flashy marketing or swish bottle and label designs. This is very much a product that lets the results do the talking. Performance wise, you can expect up to 5 months durability, but I have seen more on garage queens, less on cars parked outdoors 24/7. Collinite 845 can withstand both extreme low and high temperatures, while also providing excellent UV protection above and beyond most other waxes on the market. I have also found it to be very good at resisting bug residue.
https://www.mustang6g.com/forums/att...65-jpg.815132/
But the best thing about Collinite 845 is the majestic levels of gloss and slickness it provides. There is something so special about how this wax makes paint feel across the back of your hand.
Freshly applied 845...................
https://www.mustang6g.com/forums/att...09-jpg.815133/
https://www.mustang6g.com/forums/att...10-jpg.815134/
Where and How To Use
Collinite 845 can be used across all painted surfaces on your car. It can also be used on chrome surfaces. I would avoid contact with unpainted plastic and rubber trim, this is very much an old school wax in that it will stain those surfaces.
https://www.mustang6g.com/forums/att...e4-jpg.815135/
Like any wax, its best to apply a thin and consistent layer. Apply it too thickly, you are simply wasting product and making the wipe off harder. Because when applied thinly, the wipe off is magical!
845 can be applied by hand using a foam applicator pad, however my preference is to apply via machine as this greatly improves your ability to apply that thin, even coat. To do this, you need an ultra-soft finishing/waxing pad (see below for suggestions) and the machine set to its lowest setting. For smaller, intricate areas, you would then swap to a small hand applicator.
https://www.mustang6g.com/forums/att...07-jpg.815136/
A few years ago, the label was redesigned, the old pictured above, the new below. I love the newer versions retro look, very in keeping with the brand and product.
https://www.mustang6g.com/forums/att...59-jpg.815137/
For both hand and machine application, this is the process -
1. Wash and decontaminate the car, polish if needed. Follow with an IPA-based prep spray such as Carpro Eraser or Gyeon Prep.
2. Apply a small amount of wax to the pad (hand or machine) and squeeze or spread to prime.
3. Working panel by panel, apply a thin coat to the whole car, reapplying product to the pad as needed. Remember, a little goes a VERY long way.
4. By the time you have applied 845 to the whole car, its typically time to start removing the residue. Again, work panel by panel and swap to a clean towel as needed.
5. 845 is best left for several hours to fully harden and cure, ideally without seeing moisture or rain.
From here, you will have super glossy and ultra slick paint with impressive hydrophobic qualities.
https://www.mustang6g.com/forums/att...31-jpg.815138/
https://www.mustang6g.com/forums/att...-2-jpg.815139/
Tips & Tricks
It’s safe to say the Collinite 845 has a few quirks, quirks that could alarm you if you didn’t know better. This is probably where more modern waxes have improved the most, user friendliness. Don’t let that deter you, because 845 is well worth the effort.
1. While 845 is labelled a liquid wax, in cooler temperatures its does tend to solidify. In this case, submerge or run the bottle under hot water, this re-liquifies the wax. In warmer weather, the product is usually good to go.
2. I would stick to foam applicators with 845 over microfiber. You know the sort, those round yellow pucks sold everywhere. For machine pads, the black ShineMate (show below) or black Lake Country SDO are affordable choices.
5.5 in. Black SDO Polishing Pad (autogeek.net)
https://www.mustang6g.com/forums/att...93-jpg.815140/
3. Once primed, you only need a few drops of product per panel. The thinner the coat, the easier it will be to remove. If using a machine, unlike polishing, your arm speed can be quicker. The goal is to simply get the product on the paint, so micromanaging arm speed and working small areas is not needed.
https://www.mustang6g.com/forums/att...99-jpg.815141/
4. To see if it's time to start buffing the residue, swipe a test spot with your finger or towel. If it wipes clean, then it's time to buff. If it still feels oily or smears, then wait longer. This time frame will obviously depend on ambient temp or how thickly you applied.
5. 845 has this amazing ability to actually look glossier after 24 hours. This is due to the wax fully curing and hardening.
6. Another quirk that can appear after 24 hours is a slight hazing effect. This is completely normal, so don’t panic. Again, this is caused by the curing process as the oils rise to the surface. This haziness is then removed at the next wash, after which you will be left with slick, ultra glossy paint.
7. If you did get 845 on unpainted plastic or rubber trim, there are a couple of ways to address this. Naturally, masking these areas is the prevention. To remove residue, the old-fashioned pencil eraser trick will work here, as will a product called Nextzett Plastikreiniger (Plastic Deep Cleaner) or Meguiar's M39 (if you still have some as it's been discontinued). In either case, gently rub the affected area with the eraser or PDC/M39 with a brush, the wipe clean.
8. I have found 845 to be very receptive to follow up toppers, be that wax or ceramic based. I often have 845 as the base layer and topped with NV Jet. A polymer sealant such as Bead Maker is another perfect partner to 845.
https://www.mustang6g.com/forums/att...90-jpg.815142/
9. 845 is a nightmare to remove from your applicator. If you are using a foam applicator puck, I would just throw it away. If you have used a foam machine pad, then soaking it in APC or Rags to Riches overnight and then squeezing under hot running water will get you most of the way clean. Allow to dry and then store in a zip lock bag. Or………………..just throw the pad away.
10. A bottle of 845 will go a very looong way! In fact, I’m only on my second bottle after first trying it many, many years ago now.
Conclusions
There's no doubt that there are more durable methods of protecting your paint, likewise easier to apply waxes. But there is just something about Collinte 845 that has me coming back to it again and again. In fact, I was all set to ceramic coat my new car (if Ford ever build it), but on reflection, I'm seriously considering going back to 845. That combo of Race Red and 845 makes me smile!
https://www.mustang6g.com/forums/att...e2-jpg.815143/
Re: Collinite 845 Insulator Wax Review
Excellent write up Deyon, having applied 845 a few times already, I know exactly the smile you're talking about. I also have some Dodo Juice waxes I just can't bring myself to get rid of, they're not quite as easy to apply as 845, but the results are very similar. I have Light Fantastic, a soft wax for lighter coloured cars, expected duration is 2-3 months on a daily driver, and Blue Velvet, a hard wax for darker paints, with a similar duration. I've had them on the shelf for almost 14 years, and they still work fine.
I love 845 and used it for many years before moving on to ceramic coatings. I still have some in my garage an would use it again if the opportunity presented itself. It looks amazing on black and dark gray paint.
I have to admit for ease of application, durability, and water behavior I found Wolfgang's SIO2 Paint Sealant holds the edge, but only by a sliver. 845 is a really good product.
Thanks for the reminder!
I have a bottle I use once a year on a special car. I'm visiting friends tomorrow who just drove cross country. I'll detail their cars with an AIO and 845 would make a great topper!
I normally do my wife’s Black Mustang in 845, but this year I was considering using the Wolfgang DGPS. Should I stick with 845? I’m not worried about longevity, her car is garage kept and driven a few times a week to pick up the kids from school that’s about 1 mile from our house. I’m just looking for something that’ll really make that paint look the best it can
I’m not worried about longevity and I still use Wolfgang Fuzion. Makes my paint look phenomenal !
Collinite: STILL my go-to LSP!!
I’ve read from Collinite that it actually works good as a topper for Ceramic Coatings but that could just be them trying to sell more product.
Anyone here try it?
Also isn’t 845 more a sealant with carnauba? I know the call it a sealant but not sure how much carnauba in it…
Quote:
Originally Posted by
Coatingsarecrack
Anyone here try it?
Pretty much considered a "hybrid".
Coatingsarecrack
PaulMys
As above, its actually a hybrid wax/sealant. Most people tend to call it a wax though.
