Problem with Flex 3401 XRG
Hello
I have a Flex 3401 VRG and turns off every time I need to use.
Sometimes it runs for a panel, before it turns off unexpectedly
Sometimes it runs for 1/2 a panel, before it turns off unexpectedly
Sometimes it doesnt turn on back at all, and sometimes it does.,
I dont sense any overheating on this polisher. I have tried the manual trigger and trigger lock and no difference, still turns off
Is there something that can be done to resolve this?
Thank you
Bud
Re: Problem with Flex 3401 XRG
If the tool has brushes, it sounds like they need replacing.
Could also be a cord problem? How much run time is on it?
Had the same intermittent issue w a BOSS 21; was the brushes.
Sent from my iPhone using Tapatalk Pro
Sound like brushes, but also it could be the cable or the switch.
I can see a spark when it does run. Does that tell us anything
And where can I get brushes for the unit ? Or if Autogeek will service it
Bud
Powerhouse Distributing | Power Tool Service & Parts Supply | 402-715-5999
they are an authorized/main flex tool repair center and have been since the 3401 was released over 15 years ago...
