Polishing headlights and removing taillight spray tint
So I have a co worker who just got a 2016 mustang. He’s a good kid so I’m gonna help him out with head lights and taillights.
Do these headlights look to need sanding or can I polish. If so what should I use? I have MF and all kind of medium and light polishing pads.
For polishes Griots Correcting cream, griots glass polish (light cerium ixide) Ceriglass, Adam’s polish and Essence.
https://uploads.tapatalk-cdn.com/202...5dd4ac4120.jpg
For rears we’re trying to remove rear spray on tail light tint. I have seen video’s using gasoline and I’m thinking acetone. Anyone remove this before?
https://uploads.tapatalk-cdn.com/202...72d9e36a77.jpg
Also his grill is ashy. We’re going to test spot a trim coat and if not I’ll have him try solution finish. Looks worse than pics show
https://uploads.tapatalk-cdn.com/202...617702bfcf.jpg
Thanks in advance for the help.
Re: Polishing headlights and removing taillight spray tint
I did the lenses on my TT by hand with 4 grits of wet dry and finished with Hyper Compound and Hyper Polish.
It took forever
I’d look into one of the $25 kits with sanding discs and a backing plate you can chuck into a drill
I shudder anytime someone mentions acetone and car in the same sentence
I know there’s a formula for paint wipe using acetone but I’ve seen too much plastic instantly crazed by acetone
I did some looking around and most of the kits I saw are a magical solution of unicorn tears that you wipe on and it instantly clears the plastic and rainbows come out and stuff
Mother’s has a kit with the backing plate for a drill, what looks like foam backed abrasive discs, a compound and a fluffy looking buffing “ball”
I haven’t used it so I can’t say if it’s worth the $ but it looks a lot less like smoke and mirrors than the other kits
Meguiar’s has a kit as well but they include hand held abrasives instead of drill driven
Both were in the $20-25 range
I’m not familiar with the oversprayed taillight deal so I don’t really have any ideas other than paint stripper or something but that could get sketchy
Quote:
Originally Posted by
chilly
Sent from my iPhone using
Autogeekonline mobile app
Hey Mikey........ Empty out your PM box. :)
PaulMys
I made some room…
lol
No recommendations to answer the original question(s)...
But...
As far as the acetone you're considering on the tail lamps - Don't! Or at least don't use it without a small, inconspicuous test spot.
I'm not sure what type of plastic newer lenses are made from, but in the past, I've seen acetone melt tail and parking lamp lenses.
I wouldn’t bother trying to waste too much time restoring that grill. It’ll take too much time and won’t last as long as it takes. I’d clean it up real quick, blow dry it, and spray some Stoners Trim Shine or similar aerosol trim coating on it.
As far as the lights, 1st thing I’d do is either Mothers Mag & Aluminum Polish with a cutting pad on speed 4.5
Either that or Megs Plastx.
If that doesn’t cut it then you’ll know you have to sand.
Remember to open the hood when you’re polishing with the 3” pad.
Btw as far as that grill, is that even the real finish or is that Plastidip we’re looking at?
Eldorado2k
Real finish. Never treated. Looks pretty trashed
chilly
Griots has a kit I think I will try. Have mothers mag and wheel polish also and will give it a go [mention]Eldorado2k [/mention]
2black1s
But...
I saw a video where a guy used gasoline. What do you think of that?
