Not Just for Boats! Mildew Remover has TONS of HOUSEHOULD Use!
If you’re familiar with Marine 31 Mildew Stain Remover, you know how perfect it is to have on hand when you own a boat. As much as you try to prevent it, water and warmth is the ideal breeding ground for mildew staining and your boat has probably fallen victim to it as some point. Marine 31 Mildew Stain Remover cleans mildew stains in a flash, but did you know it can also be used on other household surfaces? What else can Marine 31 Mildew Stain Remover be used on? We’ll show you. This cooler was left in a garage after a boating trip, and it hadn’t been properly dried before storage. It quickly started to accumulate mildew stains.
https://cdn11.bigcommerce.com/s-ndtd...g?t=1662925467
Just one application of Marine 31 Mildew Stain Remover quickly removed the mildew staining and restored the coolers original finish. This screen wraps around a pool in hot and humid South Florida and if not cleaned regularly, quickly starts to show mildew staining.
Marine 31 Mildew Stain Remover was sprayed onto the screen and allowed to dwell for approximately 5 minutes. A quick wipe with a microfiber towel removed any remaining debris before rinsing cleanly away. The vinyl siding of this outdoor shed, as well as the concrete slab is sits on, are more surfaces ripe for mildew staining – their close proximity to a sprinkler and constant exposure to the heat and humidity quickly turn them into a mildewy mess.
https://cdn11.bigcommerce.com/s-ndtd...g?t=1662925967
As you can see, the Marine 31 Mildew Stain Remover not only removed the mildew staining from the vinyl siding, but from the concrete slab as well! This area took a little more elbow grease than the surfaces mentioned above, but that is to be expected considering the durability of concrete. This next example, while technically still on a boat, is a surface not many people would think to clean using Marine 31 Mildew Stain Remover. The carpet of this pontoon boat regularly sees a ton of water, but this time instead of drying, mildew grew, and the stains quickly appeared.
Luckily, Marine 31 Mildew Stain Remover is safe to use on outdoor carpet and other upholstered surfaces (but always remember to test a non-conspicuous area first to ensure colorfastness). This particular project took a lot more scrubbing than others, but regular soap and water just wouldn’t be able to remove the stains as well as Marine 31 Mildew Stain Remover did.Patio furniture that is exposed to the elements of South Florida, as these are, will definitely start to mildew if not cleaned regularly. Many times, these stains are covered by cushions but it’s still not something you want to see and sit on!
https://cdn11.bigcommerce.com/s-ndtd...g?t=1662926175
Just one application and scrub using Marine 31 Mildew Stain remover was more than enough to completely remove all mildew stains and make these chairs look brand new again!But that’s not all. Marine 31 Mildew Stain Remover can safely be used on not-so-common, household surfaces such as washing machine paddles, dishwashers, shower and sink caulking, bathroom tiles, pool decks, hot tubs, grill covers, plastic chairs, stadium seating, patio furniture, outdoor kids toys, and virtually any other surface that is susceptible to mildew staining.
Marine 31 Mildew Stain Remover, while originally designed for boats and accompanying accessories, has quickly turned into a must-have household cleaner. What have you cleaned with Marine 31 Mildew Stain Remover lately?
https://www.autogeek.net/m31-mildew-...me-guide.html/
Re: Not Just for Boats! Mildew Remover has TONS of HOUSEHOULD Use!
YUP!!
Coatingarecrack uses it on his toenails!
:laughing::laughing::cheers:
We need this in Florida this time of year!
Many uses for this product, I use it on my RV and on the driveway where the RV AC run off hits.
Best part is you hardly ever have to scrub when using this, it does all the work.
