What is your go to method for removing road grime from glass?
Hi all,
I have been using wolfgang glass polish to remove stubborn road grime that my glass cleaners just wont touch. I lost the bottle, and ive got some stubborn road grime on my windshields. I figure now is as good a time as any to explore new options.
What is your favorite or go to method for getting glass completely clean?
Re: What is your go to method for removing road grime from glass?
Not sure where you are driving to get such a build up of road grime you need glass polish...
I have found most dirt comes from the inside of the vehicle if it can't be cleaned from the outside with traditional methods.
With that said...Griots makes a fine glass polish if you elect to go that route
Quote:
Originally Posted by
Bosko
Typically its buildup outside of the wiper stroke. When dry it seems clean, if wetted at all you can see a film.
04lss
Griots Garage Fine Glass Polish
0000 steel wool has worked in the past.
Mckee’s Glass Restorer is the best I’ve come across.
Once a year I thoroughly clean the windshield to remove old sealants, road film and other undesirable elements. I start off with 0000 steel wool and Invisible Glass cleaner. Then I move on to clay. Then I clean the glass with Invisible Glass and a waffle weave glass towel. The final step before a sealant is Griots Garage Fine Glass Polish with a Rayon pad.
I have had good luck with Bon-Ami or Bar Keepers Friend.
I just bought some stoners glass stripper over Black Friday. Going to try that this weekend or next.
