Review - CarPro ReTyre Tire & Rubber Cleaner
Had a chance to use CarPro ReTyre this weekend to clean up the tires on one of my vehicles.
CARPRO ReTyre 500 ml.
Lets get a couple things straight here. The product works great and does a good job at deep cleaning the tires. The other thing is I don't let my tires get dirty. Most of us in groups like this put more care into keeping our vehicles looking nice. But it still cleaned up the tires well and left them ready for a tire dressing.
The last thing is I am not a fan of the foaming nozzle for this product. The foaming is great as it will cling to the surface to give the product time to do its work. The downside is that is uses up quite a bit of product. I used half of the bottle on 17 inch low profile tires. The possibility of overusing product is always there. My next test will be with it in a non-foaming nozzle to see how that works. This does not mean that the actual product inside the bottle is bad or does not work. It is quite the opposite.
Overall it is great to see CarPro have a dedicated tire cleaner that will deep clean and prep the tire for a tire coating where Multi X struggled at that and I would rely on another stronger tire cleaner. Now I can stay in the CarPro product line if I choose to use Cquartz BlackOut.
I rarely use a dedicated tire cleaner to clean the tires on my vehicles. An APC such as Multi X is more then enough in that aspect. But once in awhile it is good to have something stronger for those times when needed.
https://www.youtube.com/watch?v=-TMu..._channel=MikeG
Re: Review - CarPro ReTyre Tire & Rubber Cleaner
It looks like you started with a relatively clean tire to begin with and it only took two scrubbings to get it clean. I wonder how it would work on a customer's filthy tire loaded with blooming and brake dust. I like the foamy action but it looks like it uses a lot of product.
Sweet review, Mike. :)
Where did you find that kick-ass hose nozzle??
Thanks for the info and review!!!
Per Avi the foaming nozzle was chosen to not allow the product get on the wheel as it could cause issues if left on the wheel surface for a long time. ReTyre will also degrade a coating on wheels if letting it sit longer that about 5 minutes. ReTrye can also be used as a wheel cleaner but is not recommended to leave it on the wheel surface for a long period of time.
Quote:
Originally Posted by
UncleDavy
I don't keep dirty tires on my cars. So it is what it is. Have a gallon or the larger bottle if planning to deep clean a neglected tire with the foaming nozzle. It still works with a non-foaming nozzle.
PaulMys
Thanks. I purchased it from Eley under the Garden Hose Nozzle Sets
Sizzle Chest
Thanks.
Way overpriced!!!!!
Try 3D yellow degreaser for tires. 1 gallon can make 5 gallons of usable product for under 20$ if bought on sale. And it also cleans wheels and plastics.
These “specialized” cleaners are just a ridiculous money grab.
I can also get a dedicated tire/whitewall cleaner that leaves tires squeaky clean for 50$ for 5 gallon with a dilution ratio of 5:1.
These “fad” products are just a waste of our money.
Interesting product. But as you stated, you are going to blow thru the product quickly. I also use 3D YELLOW DEGREASER for wheels & tires. I use it on my tires and wheel wells.
Seems like the CarPro lovers were a bit upset in the facebook group because I apparently used too much product lol. I read some posts stating to spray a 1/4 of the tire and onto a brush and only use that amount to clean half of the tire. I will try that but I will be out of product by the time I find a dirty tire.
The Guz
I personally like to spray whole tire and let dwell. I guess you could let dwell after you scrub?
I haven’t used CarPro cleaning products (except Reset) due to the cost and what I currently used works well. I’m sure there nice.
Coatingsarecrack
Yeah you could do that. It’s a good product and it does a good job. It’s going to be hard to compete with something like McKee’s tire and rubber rejuvenator when it comes to price for a gallon.
I rarely use tire cleaners anyway as APC is more than enough for maintenance of clean tires.
