I have a Griot’s G9 DA polisher. Will Meguiars Medium Cut Cleaner #1 work with this polisher or do I need a rotary polisher?
Thanks!
Printable View
Thanks!
depends on what your goals are.
quick answer is ...no
Biscotti, Thank you for responding. Sorry I should have been more exact on my question.
I’m working on an older Toyota Tacoma with sever water spotting.
I was told to use the Meguiras #1 medium cut by a local body shop worker to bring out the best finish and possibly f/u with their swirl remover. The directions say use a rotary buffer. Will my G9 work with this product?
The pad choice will make more of a difference than that polish.....use a really good cutting pad and yes your G9 will work fine.
Thank you!
Sorry for the misspelled nome above
Dang Autocorrect….
let us know how it works out for ya:xyxthumbs:
There’s a plastic “shield” for lack of better words on the front portion of the hood, door handle and on parts of the doors. They have water spots on them. An they be buffed? If not how can I clean them?
Thanks you
try a small spot with the compound in a microfiber towel to see if you get the results you want.
Thank you, I really appreciate your help
