Hi how much is too much product?
I currently are going through alot of microfiber drying towels
I end up going over the panels twice and also tends to grab, ok when going over again.
Printable View
What are you using? For me it depends on the amount of soiling.
I don’t do waterless’s to much anymore except with Ammo Frothe.
When I did do them i would make sure the panel was sprayed till it just started dripping.
I've also stopped doing waterless. It's about the same effort to do a rinseless. I also pre-soak panels first, even with rinseless.
I only do it at home, with access to water.
I'll use the recommended dilution ratio.
Thank you for your reply.
I use WG Uber Rinseless Wash (original) at the last few gallons.
I have a gallon Uber sio2 Rinseless Wash not opened yet.
I mix for Waterless Wash.
The car is probably in generally light to moderate soiling. I wash after each time I drive it in one day of the weekend.
The car is garaged.
Rinseless is much easier and you are far more protected against any scratching… I use about five towels on a full car.
I’ve used ONR, D114, UWW in the past. I’m now using up my gallon of Pinnacle w/carnauba. D114 seems to clean the best, but I’m running out of my last gallon. UUW and Pinnacle seem slickest.
Frothe is next on my list to try.
I found ONR to be ok, nothing special. I wouldn’t buy it again.
