Re: Wolfgang sio2 question
The Wolfgang SiO2 Paint Sealant is very durable. Reapply it every 8-12 months depending on your environment. I would strip it and apply a new layer just before winter.
Quote:
Originally Posted by
jimim
Hey guys. I used wolfgangs sio2 on my Jeep last July ish. So over a year ago. When do I know I have to redo it. I have used wolfgangs sealant 3.0 for years in my Tahoe’s. I get a max 6 months out of it. But this sio2 stuff seems to be chugging along. When I wash it beads up. Smooth paint surface stuff I see zero grime spotting on the lower panels in winter. I don’t even have to work when I wash it. Everything comes right off. Winter is coming. I don’t know if I should strip it off and do a new layer? Are there signs to look for? Can I do a topper coat without doing a full decontamination and polish to clean the surface?
usually I wash, nano mitt, polish, prepaint spray, sealant.
thanks a lot!
jim
One thing to keep in mind....water beading is just an indicator of the product still being 'present'......it may not be your best indicator that it is still protecting your car's finish. I use the same sealant, and I strip it off and re-apply every 6-9 months, regardless of hydrophobic behavior.
briarpatch
Agreed. I strip and reapply every spring and fall. I wash with Wolfgang Sio2 coating wash and maintain with Wolfgang Sio2 silica spray. This regimen works great for me.&
Ok thanks guys. I wash weekly and also use the spray version weekly after each wash. I go through gallons of the stuff. Lol. Ok I’ll strip it and do it again. I appreciate the info. I figured that was the answer.
