Power Washer Spray Gun Replacement – NEED RECOMMENDATION
Greetings all! My power washer spray gun finally gave out and I need to replace it. I looking for a quality recommended replacement. I use my washer frequently for all sorts of general home, building, toy, vehicle, and shop maintenance. I’m not a commercial user, but I’d say a heavy residential user and definitely use it more for more heavy duty home maintenance type work than vehicle detailing.
My pressure washer is a Simpson model ALH3228-S, 3200 PSI, Gas, cold water washer. I was just using the OEM factory spray gun that came with it and it lasted 4 years. I would like it to have a 3/8” quick connector to attach the water hose to it and also a quick connect on the end of the wand to quickly change out the nozzles.
I was hoping to just get a kit that includes the spray gun, wand, and connections all assembled and ready to go, but would consider buying each separately if necessary. I’ll pay a little more for a quality that will last.
Thank you for any feedback!!
Re: Power Washer Spray Gun Replacement – NEED RECOMMENDATION
I would consider a MTM SGS28 or Mosmatic spray gun (with swivel). Those are both considered some of the better ones and are popular with detailers.
Yep, MTM SGS28 is pretty good. The swivel does make a huge difference.
Take a peek at this thread -
Pressure Washer Spray Gun - What's yours?
Mosmatic or MTM SGS 28 would be excellent choices.
I finally broke down 2 years ago and bought an MTM. Best decision I ever made as far as my pressure washer goes. Others would leak or break every year or 2.
I am very happy with my gun and swivel from Obsessed Garage.
I have the MTM SG35. It’s been great. If it breaks i’d probably just get the Mosmatic.
@pump_upp - best crypto pumps on telegram !
Telegram: Contact @pump_upp - best crypto pumps on telegram Make 1000% and more within 1 day, join channel @pump_upp !
1 Attachment(s)
+1 MTM Hydro Acqualine SGS35 I love the Aqualine tips to go with it.
Attachment 76267
