Microfibre drying cloths lose their ability?
I have a couple of GG PFM drying cloths, they work very well, but have been around a while and seen lots of use. I always wash microfibre towels by themselves and my go to detergent for cleaning them is 3D Towel Clean. I dry them on a medium setting on the dryer. What I have found is that a couple of these GG drying cloths just don't seem to soak up water like they used to, seems I have to go over the area a few times now to get the water soaked up. Is this normal for microfibre drying cloths, do they lose their ability to soak up with time.
Re: Microfibre drying cloths lose their ability?
Hmm. I'm stumped by this because I have the same towel which is about two years old and I have no problems. It still works just fine. I do avoid using drying aids if that could be a factor
Do you use any type of spray wax or quick detailer as you dry? That’ll diminish a towels ability to absorb after a while.
No drying aids or spray waxes used with these guys. I do use spray wax but have separate microfibres for that.
Quote:
Originally Posted by
luvmyrv
I wouldn't rule out that the spray wax you're using is somewhat water soluble even after dry. The next time you wash and dry...
I'm just taking a guess. But, somethings contaminating them.
Also, when you say wash MF towels by themselves, are you washing your PFM's with the MF's you apply the spray wax with?
I’m guesing if your investing in a MF detergent then your not using Fabric softener. Make sure non are lurking in your dryer when you dry.
Try soaking them in a strong mix of towel kleen and laundry detergent overnight.
^^^^great suggestion. I’d also like to add that you can always add a cup of white vinegar to a load.
I'd dry on low instead of medium.
Don't put those MF towels in the dryer at all.
If its a household dryer (which it likely is) then there is a chance there is a residual layer of fabric softener lined inside the tub. Its a small amount but may clog some of the fibers up over a period of time.
I really like the new Rags to Riches MF cleaner. It has restored some of my non-absorbent MF towels by way of a deep cleansing which is sticking them in a 3 gallon bucket of water with a few ounces of the RtoR, soaking 24-48 hours. Then I put them in the washer with an ounce of RtoR with a repeat on the rinse cycle to remove all the soap. Then they hang dry.
I always hang dry my MF towels. I no longer use the dryer.
evo77
I don’t have enough space on my property or inside my home to hang dry my MF’s. Also, don’t you worry about dust settling into your towels as they hang dry?
https://uploads.tapatalk-cdn.com/202...acd65d57d4.jpg
https://uploads.tapatalk-cdn.com/202...412bb4c56e.jpg
