Speed Master Paint Thickness Gauge
I saw the details on the Speed Master paint thickness meter and it implies that it can measure how much clearcoat is left, that is how thick the clearcoat alone is, not including the base coat or primer, etc. Most meters I've seen measure from the top of the painted surface to the base metal, so it doesn't measure the clearcoat alone (which is the most important if you want to know how much clearcoat you have left). So, is this meter actually able to measure only the clearcoat thickness alone? I'm wondering because it costs 4 times more than a lot of meters that can measure over steel or aluminum.
Re: Speed Master Paint Thickness Gauge
Here is the video on it. Chicago Auto Pros demoed this on one of their videos a few months ago. The thing is how long will the app be around as that is what controls the gauge.
https://www.youtube.com/watch?v=94-3...annel=Autogeek
Quote:
Originally Posted by
garfy
I doubt if it can read only clear coat. Those gauges will be closer to 10-20k. Even the 2k gauges that AG sells cannot measure only clear coat.
