Is this considered "streaking"?
I have included below an Autogeek video with Mike Phillips & Forrest Toise.
From 5:02-5:10 Forrest Toise is wiping off the lubricant (Mothers Instant Detailer), and after the second & third wipe you can briefly see where he wiped (after wiping).
This disappears after a second or two, so its nothing permanent.
I'm just wondering if this would be considered "streaking" & if so, what the possible reasons might be (something on that side of the towel, saturated towel, climate, etc).
https://youtu.be/qfbSQBzESDA?t=302
Re: Is this considered "streaking"?
Sometimes it's the carrier agents that streak before they flash off. In a QD it could be something like alcohol that evaporates.
Quote:
Originally Posted by
DUBL0WS6
I would say no. Streaking (IMO) is something that sticks around and you have to take an extra step to remove. If it flashes off in a few seconds or minutes, then like DUBLOWS6 said, it's just the carrier agents evaporating, and some take longer than others to flash off. Nothing to worry about.
DUBL0WS6
Don M
Got it. Thank you both very much. Time to look up carrier agents :D
vaced
Carrier agents are chemicals that help spread the product and speed up the drying time, sometimes called "flashing".
Rsurfer
Aren’t they also referred to as carrier oils? In regards to some sealants, they can also darken the paint, which can also sometimes leave the appearance of a streak, but there’s nothing to worry about because as mentioned anything that may appear to look like streaks goes away.
Same thing as the mythical “polishing oils”?
