Re: Travel Trailer Refresh
A cleaner wax is a reasonable choice. I'd use a non-abrasive version, e.g., OTC Meguiars in the maroon bottle, or a similar product first, to see if it provides a good enough result. If not then step up to an abrasive version, e.g., Blackfire One Step. The ribbed design has so many edges... That is why I'd start with a non-abrasive product.
Also, with the ribbed design, I don't think any random orbital polisher is the appropriate tool. It's going to be almost impossible to maintain pad rotation. A rotary, on edge or with a small pad, would be a much better choice.
As for painting over the existing decals, if you do go that route be sure the paint you use is not lacquer. Lacquer can cause the decals to "lift" and wrinkle.
That is my "traditional" or "conventional wisdom" detailing recommendation...
But since I personally can't imagine waxing something that size, especially with the ribbed design, here's a non-traditional process I might try that would take much less effort. If the finish is in reasonable condition and absent of any real oxidation, I'd thoroughly wash it with a strong detergent, e,g., Tide laundry detergent, or equivalent, to remove any road film, stains, etc., and then use a spray coating on it. Something like 303 Graphene Spray Coating or even one of today's spray and rinse coatings.
If there is any oxidation that needs to be removed, I'd try Comet cleanser.
I would stay off the decals with any type of machine and if you have some Klasse AIO, I would see what that does in a wipe on/wipe off application. Other than that, I go along with what 2black1s said - especially the rotary on edge w/ BF One Step. Just move quick. The BF One Step has chemical cleaners in it too.
Also, I would break it up into sections so you don't kill your self and never want to tackle the trailer again.
Marine/RV specific cleaner waxes or a product like BF one step would be the way I go for one reason: They can be used in sunlight.
My travel trailer is fiberglass. The thought of trying to wax a stick and tin model like yours makes me physically ill. Another thought would be a good scrubbing with a quality car wash, then something like hydro blue that you spray on and hose off.
As far as the decals, it's a 20 year old travel trailer. I'd leave them alone, or remove them all together.
I hit a few spots with Meguiars Cleaner Wax and it really brought it back to life. Cleaner and shinier. Good enough.
I also tried Blackfire one step and it was even better. I have a few bottles of the megs just collecting dust so I might as well use them up
I'm not spending a ton of time on this. Just need it to look better. I might sell it this fall and order a new one for next year
