Where do I get all the info on how much I have to spend to get a quality start/stop electric washer-is the ability to -mist- worth paying for ?
Thank you
Printable View
Thank you
How do you plan on using it? Running a business off of it or just weekend clean up duties?
Business - Kranzle K1122TST, $1,300, we've abused ours for years, worked daily 6 days a week, and it still runs like a champ. We destroyed a few $350 cheap gas pressure washers in the beginning, as they say, buy once, cry once, because you will end up spending that much anyway.
Personal - Sun Joe SPX3001, under $200, has total stop, interchangeable non-proprietary nozzles, crank hose reel, ~1.7 GPM and 2030 PSI.
Can't say I've ever had a need to mist, is this to make drying easier? I'd just run a CR Spotless system for final rinse.
Tnks for the reply. This would be for 'home' use and the budget pretty much allows for what ever it takes to get a very high quality washer, though I would like to spend less than 2 large give or take; less of course is better.
I will look into the Kranzle brand where is the unit you have made?
Misting appears to be a feature for the kung flu though I am curious as to whether or not it has applications for sealant applications and other auto related uses.
HD 2.0/1000 Dual Mister - Electric Commercial Cold Water Pressure Washer - YouTube
the link is to Kranzle
make that a link to Karcher
SunJoe SPX3000 been going strong for over 2 years now. Standard hose is 25 feet....kind of a pain. I replaced it with a 50 ft KobraJet hose from Obsessed garage.
Kranzle you can find through Obsessed Garage or DirtKiller.
I recently got a active V-52 under 300 bucks really a great bang for your buck
Check them out…if I were to or when I do upgrade I’ll give the comet a good look and the karcher too
I do really dig this little machine !
Yes I have the cox reel...SS fittings throughout....Cobra 50' hose....MTM guns and foam cannon..all wall mounted and well worth the extra cash ! serious fun with no equiptment break downs.....I look for excuses to break out all the "gear-toys"
Guessing that the Active is Chinese ?
