Hey, I have some deep scratches from a sandpaper (2000 & 2500). What I have to do now?
Printable View
First - Because this is your first post to the forum,
Welcome to AutogeekOnline! :welcome:
Second - If this is a FACTORY paint job, STOP sanding. Here's why,
Clearcoats are thin by Mike Phillips
And here's also why,
Wetsanding removes paint - Compounding removes paint - Polishing removes a little paint
If you're not careful, either via the sanding, the compounding and even the polishing - you'll go through the clearcoat layer of paint. Then the only way to fix it will be to repaint.
More...
The way you remove #2000 and #2500 grit sanding marks is via compounding.
Questions
What do you have for a polisher?
What do you have for compound?
What do you have for buffing pads?
And...
Do you have any experience doing this?
Here's a recent video where we show how to remove sanding marks via a rotary polisher.
https://youtu.be/4TtbGb0bVGI
I have nothing and no experience :/
Please listen to Mike Phillips as he is one of the best and premier detailers in the USA. You should take one of his classes or get his book on how to detail cars.
With NO EXPERIENCE, wet sanding/sanding should be done by experienced detailers. I hope this helps.
And the detailer better have a decent paint thickness gauge. Without knowing how thick the paint is, you can’t make a valid plan of attack. Some detailers pass up polishing cars due to thin paint/clearcoat. No way should wet-sanding or heavy compounding be done without knowing the thickness of the paint.
If you have nothing and no experience, take it to a body shop. It’ll cost you more to buy all the equipment and all the products that It will to have a body shop clear it up.
