Ceramic coating for preventing micro/mini srcatches?
Hello
Will the ceramic coating protect the black paint against micro / mini scratches? In general, the paint easily catches mini scratches visible only in the sun at the right angle, and I wonder if the ceramics will prevent this effect. I do not want to polish my paint with finishing compund every month just to remove this mini scratches.
Re: Ceramic coating for preventing micro/mini srcatches?
My understanding is that while ceramic coatings are scratch resistant, they are not scratch proof. A coating will help reduce scratches but will not guarantee 100% protection. So even with a coating you still have to use proper equipment and technique to minimize the chances of inducing scratches.
If you want to be 100% protected against scratches, the only product that provides that is a full-car Paint Protection Film or PPF. PPF has self-healing properties. So any scratches induced during a wash will magically disappear in the heat of the sun. But a whole car PPF can cost a lot of $$$$.
Ceramic coatings, despite some vendor claims, will not prevent or protect against swirls and light marring. They do help with things like bugs coming off easier and grime washing off easier which lessens the opportunities of swirls appearing, but they are not a protective barrier.
I own a black car as was my previous car. If you are seeing swirls developing to the point you feel you need to polish them out every month, you need to look at changing your process, products, or things like wash mitts and drying towels to keep them from appearing that quickly. I can easily go 12~18 months before I start to feel the need to polish out my black car.
Quote:
Originally Posted by
locarno
Hello
A coating can be scratch resistant. Not scratch proof. From my own personal experience, a specific section (albeit a small section) of my hood is 100% defect free according to my eyes. I applied Gyeon CanCoat on the car and have washed the car at least 10-15 times since then, maybe more using traditional 2 bucket, rinseless, and waterless wash methods. This small section shows no swirl marks or scratches to date.
I have to assume this is representative of the entire car with exception of maybe the rocker panels due to road debris, but then again expecting a coating to protect a car from road debris might be asking the coating to be scratch proof.
If you do not want to see swirls or scratches buy a white or silver car.Scratches and swirls are hard to see with those colors.
Larry A
This is true. My friend have silver car and it is really hard to see swirls or other marks.
I heard about PPF but what about yellowish after some time fro UV? Will this foil turn yellow?
locarno
That used to be an issue with the first PPF that came out a decade ago. The most recent PPF from the major manufacturers are more advanced and should not yellow over time. And if it does yellow, PPF usually comes with a substantial warranty that covers premature yellowing. I got a full-car Xpel PPF in 2018. Today it looks just as good as it did the day I got it installed. And this car is parked outside 24/7. Xpel PPF comes with a 10-year warranty that is transferable if I decide to sell the car.
locarno
Hello
A coating will help some but the biggest thing to get rid of swirls and scratches that are already there by polishing before you coat.
Then to keep from getting more swirls and scratching it’s all about how you wash and dry your car. Proper technique and products will work wonders.
If you use an automated car wash please stop.
As noted, yes and no. The key to ceramic is that they clean easier and dirt doesn't bond as easily or tightly both of which can be seen as an aid in preventing marring. Another key is in techniques for washing and drying. IMO, more on the drying side. Use a good quality MF Towel or rag that is dampened with a drying aid like a rinseless wash solution. The polymers in them won't impact the coating but offer a lubrication vs just plain water.
TTQ B4U
I completely agree with you that drying is often the culprit in inducing scratches and is often overlooked. Many people focus on proper washing techniques and forget to consider how drying may actually induce scratches and swirls. To reduce scratches induced during the drying process, you can use forced air to dry the car. If you don't have access to forced air, use a drying aid to provide sufficient lubrication as you dry. Most importantly, make sure your drying towel is clean, soft, and overall in good condition. Never wash your microfiber towels with fabric softener and only dry them in the dryer on ultra low temperature. Recently, I started washing my towels with "Rags To Riches" microfiber detergent and it cleans and reconditions microfiber towels really well.
