Opened liftgate in garage - OCD engaged
I just picked up my car a few weeks ago, PPF'd it from front to back, et al. As luck would have it though, I accidentally opened the tailgate in the garage and it left two tiny scratches/etches in the paint (about 1/8 inch each). Is there anything that I can or should do with these? Or am I just being nuts?
I know any method by hand likely won't work since I can catch them with my fingernail, but it has really triggered my OCD.
https://live.staticflickr.com/65535/...34375cd1_z.jpg
Re: Opened liftgate in garage - OCD engaged
You could try rubbing a little Meguiar's Ultimate Compound over the area and the seal with our favorite wax or sealant.
Is that area PPF'd? If so, is it self healing? If so, heat gun on low for a about 10-15 seconds at a safe 6-8". If not, don't compound or try and remove it as the clear on PPF is thin.
Quote:
Originally Posted by
TTQ B4U
That is one of the few areas that I did not get PPF'd :/
Just lightly polish to minimize the edges and make them less noticeable but since you can feel them with fingernail, they're too deep to remove, you'd blow through the clear coat.
Even with some scratches that you can feel with your fingernail, polishing cam make them almost invisible. (If they are not super deep).
Just remember to work (polish) a larger area than just the tiny area where the scratches are. Like Bruno said above, if you just take polish and aggressively go after the tiny scratch area (especially with a finger tip), it is incredibly easy to strike right through the clear coat.
PaulMys
Thank you all for the suggestions. So if I do anything, just go over it lightly by hand with a polish and applicator?
blinkme323
That's where I would start, yes.
PaulMys
Not to say that one way is right and the other wrong, but I would go at it initially with a fingertip, terry towel, and polish. Isolate the effort to the scratched area. Once the scratch is polished to your satisfaction, then go over that area and the surrounding area lightly using either microfiber or foam for the final finishing.
Although not critical in this case, my general philosophy for any type of repair is to keep the repair as small as possible, thus the fingertip method. There is no need to be removing paint one, two, or three inches away from the scratch.
PaulMys
I have Meguiars Ultimate polish on hand here, do you guys think that would suffice? I think I'll give it a shot today if so.
