Feel like idiot. Let a girl pass and she stopped so i moved little more and grazed a car but damage is not big
Just not sure how to fix this. Cant see it from distance unless closing in but makes me go crazy. I really wanna touch this up but what do i do is it fixable? The gray part is just plastic and ill just get new part for that or wrap it. But the white portion you can see. Really lightly nicked car in front of me .
Re: Feel like idiot. Let a girl pass and she stopped so i moved little more and grazed a car but damage is not big
I can't tell if there are any cracks in the paint but assuming not... Looks like the vertical portion will polish out and the horizontal piece looks like an easy touch-up.
https://www.autogeekonline.net/forum...ng+chip+repair
If the paint did crack, then repairing and repainting the bumper is the only fix.
Quote:
Originally Posted by
2black1s
How can i tell if its crack?
If it is i saw youtube where do like wet sand in this area etc is that what you mean by repair?
What horizontal part and you mean touchip with just paint?
2black1s
Also i know those meguiars like scratch x are only fillers and disguising. So not sure what to use to polish i have a da porter cable and some cutting pads and waxing pads too
animescreen
Visually inspect it.
animescreen
I mean whatever it takes to remove the cracked paint and then prepare the area for refinishing.
animescreen
The horizontal splitter or whatever you want call it below the light. Touch up as described in the attached link.
animescreen
ScratchX is not a filler... Used appropriately it will remove defects.
I'd be doing all of the polishing by hand. You're working on edges and any machine, including a DA, can be risky in those areas.
2black1s
I see so ill take some magnifying glasses and see cracks
If it doesnt have cracks im guessing clear coat and paint still got rubbed off a bit .. if that happened im guessing need to repair and touchup right wetsand etc
2black1s
I see the gray part. That can be taken out and wrapped which i was gonna do or replace which is removable
If i use hand with scratch x and see it remove the black marks it mean its restored? If black marks show it means time for wet sand and retouch
