https://sep.yimg.com/ca/I/autogeek_2268_9965684How is the Duragloss car wash? Good in a foam gun?
Printable View
Subscribed for answer[emoji362]
If I had to guess it should work just fine because I've used numerous soaps like DG's w/o a problem. I've never used Reset or Bathe in there though but then again, IMO, these are reserved for 2 BM washes, whereas a quality, less expensive carwash soap like that of DG, works great as a pre-wash or foam/dwell/rinse on a dusty car w/ great LSP[emoji362]
Sorry for possible long winded explanation [emoji4]
Really good car wash. Similar to optimum car wash and Hyperwash.
Only issue I have with it is the cherry cough syrup scent.
Yes it works fine in a foam gun. I still have an unopened gallon in the garage. You have to be okay with the cherry smell.
I've been happy with it as a hand wash.
Sent from my Pixel 3 XL using Tapatalk
I’ve used it for a long time and I’ve never noticed the scent enough to comment on it. I haven’t used it with a foam gun but I’m going to get a Foammaster soon and will be using it as I wash, not as a prewash. I have a pressure washer foam gun from MTM PF22 but it came with DP foam soap that I’m almost out of now.
I should have mentioned I recently researched this exact product for use with a Foamaster since I already have a gallon of DG901. My research suggested the foam was good though not necessarily as good as a dedicated foaming wash. However, if you want more foam using less soap, you may want to look at a product like Blackfire Foam Booster. Without Foam Booster, you may need to use 3-4 oz of soap vs 2 oz of soap with .5 oz of Foam Booster. The BF Foam Booster may be expensive but you don’t use much and it would reduce the amount of soap you need while giving more foam.
Good point on the cherry smell which is why I don’t use it.
I really like the Duragloss Rinseless wash
