Anything different about cleaning and protecting a farm tractor?
I've been debating whether to ask this question because I think the answer is obvious, but I guess I will go through with it: cleaning and protecting a modern farm tractor should work about the same as an automobile, right? Our usual tools, chemicals, and techniques wouldn't be any different aside from the size and complexity, I assume. Any experience from the group on this?
One specific question I have is the shiny (unpainted) parts of the hydraulic actuators, google tells me it's the piston rod. Without getting a close look, I'm assuming those have lubrication or something slimy and will need dirt wiped off-- would someone use chemicals to clean those parts or just wipe them down? Would trim protectant be a good choice for hydraulic hoses?
The rear end of this tractor (60hp "compact utility") has a TON of painted surfaces for the frame connections, hitches, hydraulics, etc. I can't imagine trying to ceramic coat that area, I would probably just spray HydrO2 and call it good. Comments?
Thanks
Re: Anything different about cleaning and protecting a farm tractor?
Forget about the hydraulics. That would be like protecting your shock absorber piston rods.
If you have painted surface I would wipe it down with a good spray wax like OCW, Fuzion spray wax or even Meguiars spray wax. Is it painted or powder coated?
When I read the thread title, I thought to myself "I hope Goonie75 sees this". :)
Quote:
Originally Posted by
PaulMys
Thanks brother. I happened to be browsing and baam.... there it was. Lol. Hope all is well!
Ryan
Sent from my SM-G965U using Autogeekonline mobile app
This is an old tractor with super thin paint, that is pretty much come off in a lot of areas. I did not polish, just put on some ceramic wax and top it off with a ceramic spray periodically. Clearly single stage paint.
https://uploads.tapatalk-cdn.com/202...7e2d6f85d7.jpg
Usual stuff. The paint is typically single stage enamel. I would recommend an AIO like 3D Speed or Blackfire One Step. A good strong degreaser to clean around engine, grease zerks, wheel hubs, and hydraulic fluid areas. An APC for the steps, controls, etc. and a good vinyl cleaner for the seats.
Sent from my iPhone using Tapatalk Pro
