Re: Window cleaning trick
Thanks for sharing.
For some people - the most important detail is clear glass.
Me? I hate doing windows. :D
Not to try to take away from your thread, but here's the nastiest glass I've ever cleaned.
Really really gross.
How to remove Smokers Film off inside of windshield - Review: BLACKFIRE Glass Cleaner
This is NASTY!
http://www.autogeekonline.net/galler...s_Film_001.jpg
This oily film on the inside of the windshield is called
Smoker's Film
http://www.autogeekonline.net/galler...s_Film_002.jpg
It's an oily film that builds up on the inside of a car's window glass from the smoke and carcinogens breathed out from a cigarette smoker.
http://www.autogeekonline.net/galler...s_Film_003.jpg
Not only is it difficult to remove because it's oily, it also makes driving unsafe because when the sun shines onto the windshield it dramatically increases the results of GLARE.
http://www.autogeekonline.net/galler...s_Film_004.jpg
Negatives of the above original pictures
Using a program called LviewPro, I turned the above pictures into photographic negatives.
http://www.autogeekonline.net/galler...s_Film_005.jpg
http://www.autogeekonline.net/galler...s_Film_006.jpg
http://www.autogeekonline.net/galler...s_Film_007.jpg
Look closely. See the millions of BLACK DOTS?
These are chunks of oily smoker's film that have clumped together with dirt and dust over time. If you look at the finger strokes where I wrote the word Film with my index finger, you can see where I pushed groups of the clumped oily black dots together to form darker areas in the letters
http://www.autogeekonline.net/galler...s_Film_008.jpg
That's gross....
To capture the pictures I used some Spot Lights
http://www.autogeekonline.net/galler...hp?file=108462
I'm not a pro but on our vehicles I spend extra time on the edges and corners of the windows. I use D120 and a lot of dedicated waffle weave towels to clean windows. The last thing I do is go for all edges and corners and make sure they are pristine. It makes a huge difference for anyone who looks closely and subconsciously if the edges and corners are pristine. It uses up another towel or two but I have a stack of those so no big deal.
For the interior windshield I use one of those plastic wand thingies with the handle on it (mine is Stoner but there are many variants out there). I don't use the dedicated microfiber that wraps around the edges, I just use my 16x16 waffle-weave towels layered over the flat surface of the wand head. It stays on fine when I'm wiping the glass.
Quote:
Originally Posted by
Spikey Mike
WOW!!! I am totally impressed!!! When people see me doing this they will think I'm a genius but I will definetly give the credit to YOU buddy! This is awesome!!!
Mike Phillips
Thanks for sharing.
Windows aren't great, but myself personally can't stand glare on my windows. Particularly at night while driving.
Mike Phillips
Yeah.... that's just gross.
Mike Phillips
Meguiars M122 in a half liter Mercury Kwazar will make light work of any interior windshield film.
the way we cleaned glass at the dealership was to spray glass cleaner on the glass , then wipe with a wet water sprite chamois then wipe dry with paper towels that are made for cleaning glass. we never had a problem with streaks i suppose you could use a wet towel instead of a chamois, and use a mf towel to wipe dry . you just cant spray and wipe, you have to wash the glass.
Some of you may have never seen this article I wrote.
It has some photography that was a tick tricky to obtain. I liked the title I came up with too. :D
Remove the glare from where you stare
Window Glare
http://www.autogeekonline.net/galler.../Glare_013.jpg
I used my last Monster Truck for this article.
http://www.autogeekonline.net/galler...ogeeks_SCG.jpg
And after sharing this technique and HOW and WHY it works - a good friend of mine launched their own interior glass polish.
Me? Been doing this stuff a long freaking time.
:laughing:
