Re: Beginner - Burn Through
You need to get advice from a painter, not a detailer.
As an old painter I can tell you that blending 2-component clears and expecting anything better than what I would classify as mediocre (or worse) results is not possible.
What you are trying to do, blend in the middle of a large flat panel and achieve a good result, is nearly impossible to do even for an experienced painter.
That aside, when doing any type of blending the existing finish needs to be sanded as far, or beyond, as the new topcoat will be applied.
All I can say is I admire your passion to take on such a daunting task.
I've never been a fan of "blend lines" and that's what you're going, blending a clearcoat topcoat over the repair area and then on to existing clearcoat. Afterwards, somehow sanding everything, buffing out all your sanding marks and then having the average person stand back and look at it and have it look good and also normal.
Tough to do. Like 2black1s posted, tough to do even for a experienced painter.
For reference, mostly for me, here's the link to your other thread, I'm assuming for this same project.
Beginner - Recommended Process
Thank you both very much.
I didn't know that... that it's very difficult to "blend in". I thought it was common practice. I had heard that it was difficult with paint, particularly metallic finishes but I thought (incorrectly) that Clear Coat was OK. I truly thank you for the feedback. Lesson learned.
Mike,
Yes the other thread is me. I've been fixing things all my life. To me this is just another "fixing" challenge. It does seem to have a pretty steep learning curve. :-)
Thanks again.
Quote:
Originally Posted by
Just4Fun20
Mike,
Thanks again.
There's a lot of us in the "Fixing Club".
You're in good company.
:cheers:
